ā03-10-2023 01:56 PM
I'm having some traceroute issues on a live network so I set up a super simple lab and traceroute still isn't working even though I can ping across the whole network and use 'ip route x.x.x.x' to see how routes are known.
I have a DN1 which connects to CN1; both use a p2p link on port gi1/0/23. CN1 also connects to DN2; another p2p link and both use gi1/0/24. Here's some configs. I don't have any ACLs set. No VRFs either.
-CN1's router ospf 1.
router ospf 1
router-id 10.10.10.1
passive-interface default
no passive-interface GigabitEthernet1/0/23
no passive-interface GigabitEthernet1/0/24
network 10.10.10.1 0.0.0.0 area 0
description Uplink1_To_DN1
no switchport
ip address 20.20.20.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf network point-to-point
ip ospf 1 area 0
end
no switchport
ip address 20.20.20.5 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf 1 area 0
end
-CN1_Lab#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
10.0.0.0/32 is subnetted, 3 subnets
C 10.10.10.1 is directly connected, Loopback1
O 10.10.10.2 [110/2] via 20.20.20.2, 22:15:14, GigabitEthernet1/0/23
O 10.10.10.3 [110/2] via 20.20.20.6, 22:11:19, GigabitEthernet1/0/24
20.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 20.20.20.0/30 is directly connected, GigabitEthernet1/0/23
L 20.20.20.1/32 is directly connected, GigabitEthernet1/0/23
C 20.20.20.4/30 is directly connected, GigabitEthernet1/0/24
L 20.20.20.5/32 is directly connected, GigabitEthernet1/0/24
-CN1_Lab#sh ip ospf database
OSPF Router with ID (10.10.10.1) (Process ID 1)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
10.10.10.1 10.10.10.1 1648 0x8000005C 0x006B97 5
10.10.10.2 10.10.10.2 1254 0x8000003E 0x007F5E 3
10.10.10.3 10.10.10.3 1339 0x8000003F 0x006869 3
Here's the same info for DN1.
-DN1_Lab#sh run | s router
router ospf 1
router-id 10.10.10.2
network 10.10.10.2 0.0.0.0 area 0
description CN1_P2P1
no switchport
ip address 20.20.20.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf 1 area 0
end
-DN1_Lab#sh ip route
O 10.10.10.1 [110/2] via 20.20.20.1, 22:19:00, GigabitEthernet1/0/23
C 10.10.10.2 is directly connected, Loopback1
O 10.10.10.3 [110/3] via 20.20.20.1, 22:15:00, GigabitEthernet1/0/23
20.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
L 20.20.20.2/32 is directly connected, GigabitEthernet1/0/23
O 20.20.20.4/30 [110/2] via 20.20.20.1, 22:19:00, GigabitEthernet1/0/23
-DN1_Lab#sh ip ospf database
OSPF Router with ID (10.10.10.2) (Process ID 1)
10.10.10.1 10.10.10.1 1860 0x8000005C 0x006B97 5
10.10.10.2 10.10.10.2 1464 0x8000003E 0x007F5E 3
10.10.10.3 10.10.10.3 1551 0x8000003F 0x006869 3
Same info for DN2.
description Uplink1_To_CN1
no switchport
ip address 20.20.20.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip ospf 1 area 0
end
-router ospf 1
router-id 10.10.10.3
network 10.10.10.3 0.0.0.0 area 0
-DN2_Lab#sh ip route
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
O 10.10.10.1 [110/2] via 20.20.20.5, 22:17:25, GigabitEthernet1/0/24
O 10.10.10.2 [110/3] via 20.20.20.5, 22:17:25, GigabitEthernet1/0/24
C 10.10.10.3 is directly connected, Loopback1
O 20.20.20.0/30 [110/2] via 20.20.20.5, 22:17:25, GigabitEthernet1/0/24
L 20.20.20.6/32 is directly connected, GigabitEthernet1/0/24
-DN2_Lab#sh ip ospf database
OSPF Router with ID (10.10.10.3) (Process ID 1)
10.10.10.1 10.10.10.1 35 0x8000005D 0x006998 5
10.10.10.2 10.10.10.2 1613 0x8000003E 0x007F5E 3
10.10.10.3 10.10.10.3 1696 0x8000003F 0x006869 3
So now if I'm on DN1 and I do a traceroute to DN2, I should see my first hop (hit the CN), then the DN. For some reason the traceroute doesn't work, and here is the output.
-DN1_Lab#traceroute 20.20.20.6
Tracing the route to 20.20.20.6
VRF info: (vrf in name/id, vrf out name/id)
1 20.20.20.1 2 msec 1 msec 1 msec
2 * * *
3 * * *
4 * * *
Here's the output for sh ip route x.x.x.x, and it looks correct as far as i can tell.
-DN1_Lab#sh ip route 20.20.20.6
Routing entry for 20.20.20.4/30
Known via "ospf 1", distance 110, metric 2, type intra area
Last update from 20.20.20.1 on GigabitEthernet1/0/23, 23:17:31 ago
Routing Descriptor Blocks:
* 20.20.20.1, from 10.10.10.1, 23:17:31 ago, via GigabitEthernet1/0/23
Route metric is 2, traffic share count is 1
Interestingly, if I go to the "CN" and do a traceroute to a DN, like the other end of the point-to-point, traceroute doesn't display anything at all. At least I see the first hop on a DN when doing a traceroute to another DN. Does anyone know where I can even begin to troubleshoot this?
Solved! Go to Solution.
ā03-11-2023 09:45 AM
I initially assumed that this was some sort of routing issue. But the routing is quite correct. The reason that traceroute does not work is because you have configured no ip unreachables on the interfaces. The way that traceroute works is that when you get to the destination it responds with a message indicating the destination port is unreachable. But you prevent the unreachable message from being sent.
ā03-13-2023 07:57 AM
Thank you, this makes sense. I tested it out on my lab too. I had to do a deeper dive into traceroute to see exactly how it works but now I'm better for it.
ā03-14-2023 11:47 PM
I am glad that my explanation was helpful and that now you have a better understanding of traceroute. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
