09-27-2024 10:34 AM - edited 09-27-2024 10:54 AM
I have three ISPs configured in Cisco ASA. Route 1 and 2 are tracked. If ISP1 goes down it will switch to ISP2. If ISP2 goes down too it will switch to ISP3.
Yesterday everything looked good and worked. Today I noticed in the ASDM firewall log that ASA is deleting and creating routes every ~5 second.
I can successfully ping every destination (8.8.8.8, 1.1.1.1) from every ISP interface from the ASA.
The track and sla configuration looks like this:
sla monitor 150
type echo protocol ipIcmpEcho 8.8.8.8 interface WAN1
threshold 1000
frequency 10
sla monitor schedule 150 life forever start-time now
sla monitor 160
type echo protocol ipIcmpEcho 1.1.1.1 interface WAN2
threshold 1000
frequency 10
sla monitor schedule 160 life forever start-time now
In sla debug I get:
IP SLA Monitor(160) Scheduler: Starting an operation
IP SLA Monitor(160) echo operation: Sending an echo operation
IP SLA Monitor(150) Scheduler: Starting an operation
IP SLA Monitor(150) echo operation: Sending an echo operation
IP SLA Monitor(150) echo operation: RTT=10
IP SLA Monitor(150) Scheduler: Updating result
IP SLA Monitor(160) echo operation: Timeout
IP SLA Monitor(160) Scheduler: Updating result
IP SLA Monitor(160) echo operation: RTT=10
What could that be? Is this somehow related to two trackings?
Solved! Go to Solution.
10-01-2024 11:52 AM
I have found the cause! The router in front of the firewall caused that route flapping.
It looks like icmp traffic originated from the firewall could not be send back to the correct firewall interface. This router handels two ISP provider in the current phase of configuration.
09-27-2024 11:12 AM
what ASA code running on this device ?
we only see sla monitor, can you show us more information what is the action you doing.
some test i doing the Lab for dual ISP should be same for Tipple ISP :
https://www.balajibandi.com/?p=1932
09-27-2024 11:17 AM - edited 09-27-2024 11:22 AM
ASA is running on 9.20(3).
track 1 rtr 150 reachability
track 2 rtr 160 reachability
route WAN1 0.0.0.0 0.0.0.0 10.10.10.10 1 track 1 (public ISP ip)
route WAN2 0.0.0.0 0.0.0.0 20.20.20.20 2 track 2 (public ISP ip)
route WAN3 0.0.0.0 0.0.0.0 192.168.150.1 3
09-27-2024 12:47 PM
Can post sla output and show route output ?
09-27-2024 01:26 PM - edited 09-27-2024 01:35 PM
asa/pri/act# sh sla mon conf
SA Agent, Infrastructure Engine-II
Entry number: 150
Owner:
Tag:
Type of operation to perform: echo
Target address: 8.8.8.8
Interface: WAN1
Number of packets: 1
Request size (ARR data portion): 28
Operation timeout (milliseconds): 5000
Type Of Service parameters: 0x0
Verify data: No
Operation frequency (seconds): 10
Next Scheduled Start Time: Start Time already passed
Group Scheduled : FALSE
Life (seconds): Forever
Entry Ageout (seconds): never
Recurring (Starting Everyday): FALSE
Status of entry (SNMP RowStatus): Active
Enhanced History:
Entry number: 160
Owner:
Tag:
Target address: 1.1.1.1
Interface: WAN2
Verify data: No
Enhanced History:
asa/pri/act# sh sla mon oper
Entry number: 150
Modification time: 19:16:17.640 CEST Fri Sep 27 2024
Number of Octets Used by this Entry: 2056
Number of operations attempted: 1152
Number of operations skipped: 0
Current seconds left in Life: Forever
Operational state of entry: Active
Last time this entry was reset: Never
Connection loss occurred: FALSE
Timeout occurred: FALSE
Over thresholds occurred: FALSE
Latest RTT (milliseconds): 10
Latest operation start time: 22:28:07.641 CEST Fri Sep 27 2024
Latest operation return code: OK
RTT Values:
RTTAvg: 10 RTTMin: 10 RTTMax: 10
NumOfRTT: 1 RTTSum: 10 RTTSum2: 100
Entry number: 160
Modification time: 20:57:11.732 CEST Fri Sep 27 2024
Number of Octets Used by this Entry: 2272
Number of operations attempted: 546
Latest operation start time: 22:28:41.732 CEST Fri Sep 27 2024
RTT Values:
Gateway of last resort is 10.10.10.10 to network 0.0.0.0
S* 0.0.0.0 0.0.0.0 [1/0] via 10.10.10.10, WAN1
C 10.10.10.9 255.255.255.248 is directly connected, WAN1
L 10.10.10.11 255.255.255.255 is directly connected, WAN1
C 20.20.20.19 255.255.255.248 is directly connected, WAN2
L 20.20.20.21 255.255.255.255 is directly connected, WAN2
C 192.168.150.0 255.255.255.248 is directly connected, WAN3
L 192.168.150.2 255.255.255.255 is directly connected, WAN3
I have removed internal routes from output.
After I have disabled the SLA160 some several minutes an enabled it later again, the issue is currently not present. But I have to make sure that it doesn't happen again.
09-28-2024 01:32 AM
i do not see high level any issue. make sure device have latest IOS Code running and keep Monitor and let us know how that goes.
also you can simulate remove the WAN1 and WAN2 all working as expected as part of testing, when no peak time ?
09-30-2024 08:26 AM - edited 09-30-2024 08:36 AM
Today after I have booted both firewalls the issue is present again. This setup is not running in a productiv environement yet, so it was turned off.
It's adding and removing routes continously. I have no clue what's causing this. Every ISP-interface on the ASA can ping it's gateway and a random destination on WAN, like 1.1.1.1.
Entry number: 150
Modification time: 16:33:25.276 CEST Mon Sep 30 2024
Number of operations attempted: 326
Latest operation start time: 17:27:25.277 CEST Mon Sep 30 2024
RTT Values:
Entry number: 160
Modification time: 16:33:25.277 CEST Mon Sep 30 2024
Timeout occurred: TRUE
Latest RTT (milliseconds): NoConnection/Busy/Timeout
Latest operation start time: 17:27:55.272 CEST Mon Sep 30 2024
Latest operation return code: Timeout
RTT Values:
RTTAvg: 0 RTTMin: 0 RTTMax: 0
NumOfRTT: 0 RTTSum: 0 RTTSum2: 0
09-30-2024 10:38 AM
what is the Model of ASA and code running, can you post all your show run removing confidence information.
so i can look and simulate for you.
09-30-2024 11:25 AM - edited 09-30-2024 11:29 AM
Secure Firewall 3105, ASA is running 9.20(3).
asa/pri/act# sh run ASA Version 9.20(3) ! hostname asa enable password service-module 0 keepalive-timeout 4 service-module 0 keepalive-counter 6 service-module 1 keepalive-timeout 4 service-module 1 keepalive-counter 6 passwd ! license smart feature tier standard feature strong-encryption names no mac-address auto ! interface Ethernet1/1 description LAN/STATE Failover Interface ! interface Ethernet1/2 shutdown no nameif no security-level no ip address ! interface Ethernet1/3 shutdown no nameif no security-level no ip address ! interface Ethernet1/4 shutdown no nameif no security-level no ip address ! interface Ethernet1/5 shutdown no nameif no security-level no ip address ! interface Ethernet1/6 shutdown no nameif no security-level no ip address ! interface Ethernet1/7 no nameif no security-level no ip address ! interface Ethernet1/8 no nameif no security-level no ip address ! interface Ethernet1/8.130 no nameif no security-level no ip address ! interface Ethernet1/9 description isp switch channel-group 2 mode active no nameif no security-level no ip address ! interface Ethernet1/10 description isp switch channel-group 2 mode active no nameif no security-level no ip address ! interface Ethernet1/11 shutdown no nameif no security-level no ip address ! interface Ethernet1/12 shutdown no nameif no security-level no ip address ! interface Ethernet1/13 shutdown no nameif no security-level no ip address ! interface Ethernet1/14 shutdown no nameif no security-level no ip address ! interface Ethernet1/15 description core switch channel-group 1 mode active no nameif no security-level no ip address ! interface Ethernet1/16 description core switch channel-group 1 mode active no nameif no security-level no ip address ! interface Management1/1 management-only shutdown no nameif no security-level no ip address ! interface Port-channel1 description core switch no nameif no security-level no ip address ! interface Port-channel1.100 vlan 100 nameif Transit-Net security-level 90 ip address 192.168.150.1 255.255.255.254 ! interface Port-channel2 description isp switch no nameif no security-level no ip address ! interface Port-channel2.150 description wan1 vlan 150 nameif WAN1 security-level 0 ip address 10.10.10.10 255.255.255.248 ! interface Port-channel2.160 description wan2 vlan 160 nameif WAN2 security-level 0 ip address 20.20.20.20 255.255.255.248 ! interface Port-channel2.170 description wan3 vlan 170 nameif WAN3 security-level 0 ip address 30.30.30.30 255.255.255.248 ! boot system disk0:/cisco-asa-fp3k.9.20.3.SPA ftp mode passive clock timezone xxx dns domain-lookup WAN1 dns domain-lookup WAN2 dns domain-lookup WAN3 dns server-group DefaultDNS name-server 1.1.1.1 same-security-traffic permit intra-interface no object-group-search access-control <objects removed> access-group Transit-Net_access_in in interface Transit-Net access-group WAN1_in_1 in interface WAN1 access-group WAN2_access_in in interface WAN2 access-group WAN3_access_in in interface WAN3 <acls removed> pager lines 24 logging enable logging timestamp logging asdm informational mtu Management 1500 mtu Transit-Net 1500 mtu WAN1 1500 mtu WAN2 1500 mtu WAN3 1500 failover failover lan unit primary failover lan interface Failover-Link Ethernet1/1 failover link Failover-Link Ethernet1/1 failover interface ip Failover-Link 192.168.190.1 255.255.255.252 standby 192.168.190.2 failover ipsec pre-shared-key 8 xxx no failover wait-disable no monitor-interface Management monitor-interface Transit no monitor-interface WAN1 no monitor-interface WAN2 no monitor-interface WAN3 no monitor-interface service-module icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-openjre-7202.bin no asdm history enable arp timeout 14400 no arp permit-nonconnected arp rate-limit 32768 nat (Transit,WAN1) source dynamic any interface nat (Transit,WAN2) source dynamic any interface nat (Transit,WAN3) source dynamic any interface route WAN1 0.0.0.0 0.0.0.0 10.10.10.10 1 track 1 route WAN2 0.0.0.0 0.0.0.0 20.20.20.20 2 track 2 route WAN3 0.0.0.0 0.0.0.0 30.30.30.30 3 <routes removed> timeout xlate 3:00:00 timeout pat-xlate 0:00:30 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00 timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute timeout tcp-proxy-reassembly 0:01:00 timeout floating-conn 0:00:00 timeout conn-holddown 0:00:15 timeout igp stale-route 0:01:10 user-identity default-domain LOCAL aaa authentication ssh console LOCAL aaa authentication login-history http server enable http server idle-timeout 30 no snmp-server location no snmp-server contact sla monitor 150 type echo protocol ipIcmpEcho 8.8.8.8 interface WAN1 threshold 1000 frequency 30 sla monitor 160 type echo protocol ipIcmpEcho 1.1.1.1 interface WAN2 threshold 1000 frequency 30 crypto ipsec security-association pmtu-aging infinite crypto ca trustpoint _SmartCallHome_ServerCA no validation-usage crl configure crypto ca trustpoint _SmartCallHome_ServerCA2 no validation-usage crl configure crypto ca trustpoint ASDM_TrustPoint0 enrollment terminal subject-name CN= xxx crl configure crypto ca trustpoint ASDM_TrustPoint1 keypair ASDM_TrustPoint1 crl configure crypto ca trustpool policy auto-import crypto ca certificate chain _SmartCallHome_ServerCA ! track 1 rtr 150 reachability ! track 2 rtr 160 reachability telnet timeout 30 ssh stricthostkeycheck ssh timeout 30 ssh key-exchange group dh-group14-sha256 console timeout 0 no vpn-addr-assign aaa no vpn-addr-assign dhcp no ipv6-vpn-addr-assign aaa no ipv6-vpn-addr-assign local threat-detection basic-threat threat-detection statistics threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200 ntp authentication-key 1 md5 8 xxx ntp authenticate ntp trusted-key 1 enable WAN1 enable WAN2 http-headers hsts-server enable max-age 31536000 include-sub-domains no preload hsts-client enable x-content-type-options x-xss-protection content-security-policy anyconnect image disk0:/secure_client/cisco-secure-client-win-5.1.6.103-webdeploy-k9.pkg 1 anyconnect profiles SecureClient1 disk0:/secure_client/secureclient1.xml keepout "." cache disable error-recovery disable class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum client auto message-length maximum 512 no tcp-inspection policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect sip inspect netbios inspect tftp inspect ip-options class class-default user-statistics accounting ! service-policy global_policy global prompt hostname priority state no call-home reporting anonymous call-home profile License destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService destination transport-method http profile CiscoTAC-1 no active destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService destination address email callhome@cisco.com destination transport-method http subscribe-to-alert-group diagnostic subscribe-to-alert-group environment subscribe-to-alert-group inventory periodic monthly subscribe-to-alert-group configuration periodic monthly subscribe-to-alert-group telemetry periodic daily password encryption aes hpm topN enable no flow-offload enableThat would be really great if you could test it. My current guess is that the ASA can't handel two tracked routes because there is no boolean link between route 1 and 2.
09-30-2024 12:17 PM
You have port-channel sub-interface configured here, what is the other side connected to Switch, what switch can you post that switch config, and is all the ISP connected to that switch ?
why do you need port-channel you have many interface on device can you not connected directly to ISP to this ports ?
09-30-2024 10:43 AM
you have three ISP?
did you try add different AD to third route and check
MHM
09-30-2024 11:26 AM
Yes three ISP.
Different AD?
09-30-2024 11:32 AM
Use 8.8.4.4 instead of 1.1.1.1 and check
MHM
09-30-2024 11:48 AM
I changed metric to 254 and 1.1.1.1 to 8.8.4.4. Units are rebooting now because after disabling and enabling SLA again, routes don't flap (same like last week).
I will report back in some minutes.
09-30-2024 11:52 AM
The defualt route toward wan2 must have less AD than third defualt toward wan3
So make second ad 200
Third make it ad 254
Note:- dont use ad 255 it not work in ftd/asa
MHM
