traps not being sent
MZydorczyk2
I have macnotification traps enabled and originally I thought I was having a problem receiving the traps but using "show" I see that they are not even being generated because the counters are not being incremented. Any clue on what else I might need to enable?
19 Replies 19
Thanks. We will try upgrading to a newer version to see if it fixes the problem.
While on the topic of traps, is there anyway you can have a switch (4000s, 4500s, and 6500s) send traps on things that aren't specificly in the config mode?
You can enable all traps:
snmp-server enable traps
snmp-server host 10.1.1.1 traps public
For CatOS:
set snmp trap enable all
set snmp trap 10.1.1.1 public
But what I'm asking is that if I enable "all" traps, those are the ONLY ones I can have (the ones the "all" parameter includes)?
Yes. That will enable all the traps the device supports. To get new traps you'd have to upgrade to a software version in which they've been added.
Ok thank you. That's the answer I was looking for.
