Trouble deleting device from DCR using dcrcli in CiscoWorks
rcurran02
I am trying to delete a device from the DCR in LMS 3.2 using the dcrcli command below:
dcrcli -u dnescripting cmd=del id=5052
I am getting to following error after running that command:
<dcrcli> * Password file found using DCRCLIFILE environment variable.
Error in Delete Device:  Device is still managed by application(s).
Does anyone know how I can get around this and make the device not "management by  applications" through an option added to the dcrcli command?
Thanks Ryan.
Joe Clarke
Use del -f to force deletion:
dcrcli -u dnescripting cmd=del -f id=5052
that worked, thanks for your help!
