Troubleshooting Over Utilisation on Network
buzzhani1
I have a cisco 1941 router connected to a switch, and a modem. I suddenly noticed a huge slow down with the internet connection. It happened very abruptly. I did an isolated test and noticed i was getting the usual bandwidth from the ISP but when connected to the LAN, the connection slows down drastically. It is crawling. I suspect over utilisation from the LAN, maybe from a user but how do i check where the traffic is coming from? Please any ideas on how to troubleshoot this? Is there a way to check the bandwidth consumed by each client connected to the network?
Thanks.
ronpestler1
Hi buzzhani1,
when you need only the meta informations you can configure your 1941 to send flows to a collector.
Or when you dont need history you can view that information (Src / Dst / Port and so on) also
via cli.
flow exporter flow-exporter
 description Export
 destination <IP from collector> <Port>
 source <Interface from which you can reach the collector>
 template data timeout 60
flow monitor flow-monitor
 record netflow-original
! Or use this
! record netflow ipv4 original-input
 cache timeout active 60
interface <lan-interface>
 ip flow monitor flow-monitor input
 ip flow monitor flow-monitor output
Check
show flow monitor flow-monitor statistics
Caution the flow generation need cpu utilization!
As collector you can use different Software (IsarFlow or from Solarwinds, Manageengine and so on)
Best regards
