WS-C2960+24TC-L System Temperature Status via SNMP
vojtech.krejsa1
Hi all,
I need to diagnose System Temperature Status (Board Temperature) via SNMP on my device WS-C2960+24TC-L.
I found the following OIDs:
chassisFanStatus 1.3.6.1.4.1.9.5.1.2.9.0
(other (1) - none of the following, ok (2) - status OK, minorFault (3) - minor problem, majorFault (4) - major problem)
and
chassisTempAlarm 1.3.6.1.4.1.9.5.1.2.13.0
(off (1) - temperature within normal range, on (2) - temperature too high, critical (3) - critical temperature, system shut down imminent)
In normal state I displayed the following states in concole:
bila_tremesna>show env all
FAN is OK
SYSTEM TEMPERATURE is OK
POWER is OK
RPS is NOT PRESENT
21.4.2016 8:21:23 (152 ms) : 1.3.6.1.4.1.9.5.1.2.9.0 = "2" [ASN_INTEGER]
21.4.2016 8:21:23 (195 ms) : 1.3.6.1.4.1.9.5.1.2.13.0 = "1" [ASN_INTEGER]
When I disconnect the Fan, the FanStatus goes to "4" and in console is displayed:
FAN is FAULTY
SYSTEM TEMPERATURE is FAULTY
POWER is OK
RPS is NOT PRESENT
21.4.2016 8:21:12 (144 ms) : 1.3.6.1.4.1.9.5.1.2.9.0 = "4" [ASN_INTEGER]
21.4.2016 8:21:12 (188 ms) : 1.3.6.1.4.1.9.5.1.2.13.0 = "1" [ASN_INTEGER]
So, in the console, the state of System Temperature is changed to FAULTY, but in SNMP is "1" (not change). Is this correct state?
Thank you
VojKrej
Philip D'Ath
What software version are you using?
Here is the version:
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 15.0(2)SE6, RELEASE SOFTWARE (fc2)
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 15.0(2r)EZ1, RELEASE SOFTWARE (fc1)
Thank you for your reply
Hmm, I suspect this will be a platform limitation then.
