Troubleshooting
clevend
Community Member
Hi guys,
I work as network engineer. I work with Switches ( Catalyst, Nexus), routing ( BGP for the most part) and firewalls (ASA, Checkpoint).
Is there good resource to level up my game in troubleshooting. Manuals, videos or whatever helped you to learn and up your game in working with protocols and also troubleshooting them.
I also have eve ng lab ( 40 cores 128 gig ram), so if you have any labs to recommend I'd be happy 🙂
carstenlymann1
Level 4
Level 4
Hi @clevend
I would say the best t-shoot resource, is doing the daily t-shoot. And if you have a more experienced co-worker close to you, that can help out and give hint along the way that is by far the best way. I know its not always possible to do that, 😉
https://learningnetworkstore.cisco.com/on-demand-e-learning in here is a really great resource for learning. Video, practice questions and labs.
https://www.cbtnuggets.com/it-training/cisco/ccnp-routing-and-switching this one although old and not apply 100% to current certification. The old ccnp t-shoot.. This course has a lab with 18 tickets, that need to be solved. You learn to t-shoot all kind of stuff, and there is help along the way from the videos if needed.
Please remember to select a correct answer and rate helpful posts
/ Carsten
