Trying to monitor Transmit and Receive sensor
Hi all, i am trying to get value using SNMP for Te1/0/1 Transmit Power Sensor and Te1/0/1 Receive Power Sensor on cisco 3850:
Model Number                       : WS-C3850-12XS
Switch Ports Model              SW Version        SW Image              Mode
*    1 16    WS-C3850-12XS      03.07.04E         cat3k_caa-universalk9 INSTALL
CISCO-OPTICAL-MONITOR-MIB says i can use OID starting with 1.3.6.1.4.1.9.9.264 but i receive no response from switch with snmp tester. Is my 3850 "not able" to do it or else ? Many others OID are working fine on this 3850 and cli sh int Te trans detail works fine too.
Many thanks for help if possible.
Regards.
Hervé.
Mark Elsen
 - You may have a try with the latest advisory software release for the 3850 and check if that makes any difference.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
7 Replies 7
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Thanks for quick reply, i will ask client to upgrade software version before going any further.
balaji.bandi
what is the out come of below command :
show interfaces gigabitEthernet e1/0/1 transceiver detail
BB
Oleg Volkov
Hi, I have PRTG sensor for monitoring SFP levels by SSH - for this case.
Because sometimes we can not upgrade software in short time
Helping seriously ill children, all together. All information about this, is posted on my blog
Hi Oleg, thanks for the reply i am interested in testing this sensor .. but after all i have just for Cisco 3850 to monitor and i wonder if these 3850 are worthy to spend time in deploying such sensors...
So if you feel kind enough to show me how your sensor works, it will be very appreciated, but i will use it only if strongly needed.
Thanks and regards.
Hello!
https://github.com/OlegPowerC/sfpddmssh
This sensor can do it
Hi Oleg, thanks for sharing it, i will try it.
