Trying to upgrade to LMS 4.0.1
pmet
I have installed the LMS 4.0 and i am trying to apply the upgrade 4.0.1 . When the installation starts after a while suddenly the machine reboots .
The machine is Windows 2008 R2 64bit . I am trying to find any logs why it happens but nothing .
Any ideas ?
Makis
6 Replies 6
Michel Hegeraat
Level 7
Level 7
The windowns event logs for system and application should tell you what went wrong.
Is it at the same point in the installation where the box reboots? Anything in the install logs?
Also you can put the crmdmgtd service to manual, reboot, and then try the upgrade.
After the install put it back to automatic
Cheers,
Michel
Thanks for your reply .
As i can monitor it is at the same point , about 15% when the installation bar starts .
I tried also with crmdmgtd to manual instead of automatic .
From windows event viewer i get the following Application Error message
Faulting application name: cwlms4_0_1_win_k9.exe, version: 15.0.0.603, time stamp: 0x4a030a42
Faulting module name: ISSetup.dll, version: 15.0.0.591, time stamp: 0x48c89fa2
Exception code: 0xc0000005
Fault offset: 0x0009c443
Faulting process id: 0xa70
Faulting application start time: 0x01cc419dae0eacc6
Faulting application path: C:\psu_download\lms\cwlms4_0_1_win_k9\cwlms4_0_1_win_k9\cwlms4_0_1_win_k9.exe
Faulting module path: C:\Users\ADMINI~1\AppData\Local\Temp\2\{1B8BE7BD-9443-4365-9916-37C64124EBC1}\ISSetup.dll
Report Id: cabb6c3d-ad91-11e0-9741-00215e55b2de
Also can you advice me which of the log file (cisco works )  should i search for error messages ?
Best Regards
Makis
The installation log is in  C:\    post the newest one here
Are you trying this as a local administrator?
Cheers,
Michel
Hello
Yes i run the setup as a local administrator
I upload the latest install log file . I didnt find something that could help why it crashes .
Makis
No, it all looks fine in the log
It actually gets towards the post-install part of the 4.01 installation.
No idea why this happens. If there is nothing else in the system and application logs then it is a mistery to me.
Only thing different with an installion in my lab is that I have all installation executable cwlms4_0_1_win_k9.exe already unpacked in c:\install.
Cheers,
Michel
Also i forgot to send you the Application Error from windows logs .
Event 1000 , Application Error
Faulting process id: 0xab8
Faulting application start time: 0x01cc4567f8639095
Faulting application path: C:\install\cwlms4_0_1_win_k9\cwlms4_0_1_win_k9\cwlms4_0_1_win_k9.exe
Faulting module path: C:\Users\ADMINI~1\AppData\Local\Temp\{EA056C3D-040B-4757-BFE7-E30D2034BFCB}\ISSetup.dll
Report Id: e83c5ec7-b15b-11e0-81ac-00215e55b2de
I also tried to download again and extract the installation file to another folder , but again it crashes .
Best Regards
Makis
