02-03-2005 05:11 AM
Has anyone got UGCA to work?
Even after I've ran the repairsyslog.nawk command it still doesn't process any Call records.
I just can't load any into the db.
#./loadcdr_file.sh /tmp/sys.new sys.rst
Job started successfully, please check job information for details.
# more sys.rst
================= Summary =================
Status : Completed
Start time : 2005-02-02 14:43:54 GMT+02:00
End time : 2005-02-02 14:43:54 GMT+02:00
Time (s) : 0.34
Total syslog msgs : 55
Total CR to DB : 0
Total Markup to DB : 0
Total MCR to DB : 0
Total inserted to DB : 0
Total failed CR : 15
Total failed MCR : 14
Av. insert rate (/s) : 0.00
Av. CR ins. rate(/s) : 0.00
Files processed : /tmp/sys.new
Files failed :
02-09-2005 06:30 AM
Here is a document on UGCA that discusses about the general configuation tasks. Check if you have done everything in accordance : http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/ugm/ugca/ugca_ug/mhugintr.htm#68078
05-04-2006 07:05 PM
Hi all,
I have the same problem with my UGCA.
Is there any relation with solaris and J2SE patches ?
Thank you.
Aris Cahyadi R.
