PI not start - java error
Ralf Boehm
Level 2
Level 2
I got a java error, see the following text, if I tried to start ncs or check status:
ncs status
Exception in thread "main" java.util.NoSuchElementException
        at java.util.Scanner.throwFor(Scanner.java:862)
        at java.util.Scanner.next(Scanner.java:1371)
        at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAvailabilityConfig.java:232)
        at com.cisco.common.ha.config.HighAvailabilityConfig.parseXmlFile(HighAvailabilityConfig.java:214)
        at com.cisco.common.ha.config.HighAvailabilityConfig.<init>(HighAvailabilityConfig.java:194)
        at com.cisco.common.ha.config.HighAvailabilityConfig.getInstance(HighAvailabilityConfig.java:203)
        at com.cisco.packaging.HMAdmin.initHealthMonitorApi(HMAdmin.java:409)
        at com.cisco.packaging.HMAdmin.hmServerStatus(HMAdmin.java:302)
        at com.cisco.packaging.HMAdmin.status(HMAdmin.java:172)
        at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:1053)
        at com.cisco.packaging.WCSAdmin.status(WCSAdmin.java:1026)
        at com.cisco.packaging.WCSAdmin.runMain(WCSAdmin.java:314)
        at com.cisco.packaging.WCSAdmin.main(WCSAdmin.java:1493)
The problem was, the file
/opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config/haSettings.xml
was empty. For my luck, I found a copy in the same directory:
haSettings_bkup.xml
Copy this file to haSettings.xml, and all works fine. I do not know, why these file was empty.
Hello, sure, I have do this befor. Have enough space. The solution is: The problem was, the file /opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config/haSettings.xml was empty. For my luck, I found a copy in the same directory: haSettings_bkup.xml Copy this file to haSettings.xml, and all works fine.
17 Replies 17
Mark Elsen
  - Check for possible disk space issues ; connect via SSH  and issue
                    admin # show disks
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi!
@Ralf Boehm
Could You paste that config file here so other can see?
I might have the same issue, but I do not have backup of this file.
Hello, that would be not help you. Because the file contains a authenticationKey and a sharedKey. And these are not the same for your installation. MfG Boehm
My setup is standalone @Ralf Boehm
Please share, You can remove any important details, I have no choice.
Seems disk space issue overwritten it... and there is a bug to address this :
https://quickview.cloudapps.cisco.com/quickview/bug/CSCuy39464
Hello, ok, here is the content of the file /opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config/haSettings.xml: All information, like keys etc., are replaced with "X". We have only a standalone installation, but this file is necessary. MfG Boehm
Sorry, Ihave forgot the file. 😕 When use, remove "txt" at the end of the filename.
Thank You @Ralf Boehm !
My prime infrastructure is back up! No issues with licenses either, will let You know if anything is incorrect, so far so good, so this will be helpful for others later 😉
Hello, Please let me know. where can I find the directory /opt/...
and where i can place this file?
How I can copy and paste this file in /opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config/
Hello, have you a file? If yes, you have to login via ssh. Then call the cmd "shell". Then change to the directory "/opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config". Use vi to create the file. MfG Ralf Boehm
after create the file whatis next? I already have this file exist haSettings.xml with 0 size.  Need help to make prime work.
masiyus
Frequent Visitor
Frequent Visitor
Hello, you have to login via ssh. Then call the cmd "shell". Then change to the directory "/opt/CSCOlumos/conf/rfm/classes/com/cisco/common/ha/config". There must be the file "haSettings.xml". MfG Boehm
