Unable to connect to ANI Server
sirbaughmf
I'm running LMS 3.1 with CM 5.1.0 on a single Solaris 9 server. I've been unable to open topology services. I get an error "cannot connect to ANI server". I've confirmed that the ANIServer6.0 is running (it says "Running with busy flag set"). I've also tried restarting the Daemon Manager. What should I look at? Could it be a Java problem?
16 Replies 16
That seems to have worked! I'll continue testing to see if there are any other problems. I also tried changing the /etc/nodename to the FQDN and that worked as well. However, I was concerned about what would happen if the server rebooted, so I changed that back.
Thanks!!! It's works!
