unable to connect to LMS web interface
zealot9000
Hello. Disappeared access to the web interface. Here is what the system:
#pdshow Apache
        Process= Apache
        State  = Administrator has shut down this server
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 11/27/13 12:52:34
        Stop   = 11/27/13 12:52:34
        Core   = Not applicable
        Info   = Application started by administrator request.
What could be the problem? Thanks in advance.
5 Replies 5
AFROJ AHMAD
what is the OS ?
share the screen shot of services.msc  if it is a windows server
share the Error.log from NMSROOT/CSCOpx/MDC/Apache/logs
share the ouput of pdshow command
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Hello Afroz.
OS - Red Hat Linux
pdshow - http://pastebin.com/qkq6scqA
I can not understand where Apache stores its logs.
It is not just Apache , I can see a lot of IMP services are down
like
Process= DCRServer
        State  = Never started
Process= jrm
etc....
Is this a Fresh Installation ?
can you share the Installation.log ( you will  it under
under /var/tmp/. And
format of the log files is Cisco_Prime_install_XXX.log)
share the  regdaemon.xml and regdaemon.xml.bak located under...\CSCOpx\MDC\etc\.
Also provide the stdout.log.* located under /CSCOpx/MDC/tomcat/logs.
and Syslog_info from /var/log
Thanks-
Afroz
Hello.
Yes, this is a new installation.
Cisco_Prime_install_20120209_113107.log http://pastebin.com/rgNEhyd3
regdaemon.xml http://pastebin.com/tCeYzMZi
regdaemon.xml.bak http://pastebin.com/y7gnCsvE
stdout.log http://pastebin.com/7mNamb2b
stdout.log-OLD-1 http://pastebin.com/wxv8NiP1
stdout.log-OLD-2 http://pastebin.com/1WqbTQRf
http://pastebin.com/1WqbTQRfstdout.log-OLD-3 http://pastebin.com/2frfWs0Z
Syslog_info - file weighs 373 MB. Pour it on file sharing?
I am unable to access the logs. Did you see a differnece in the files size of Regdaemon.xml and regdaemon.xml.bak ?
Was this working before ?
share just the stdout.log , you should be able to uplaod  this file here..
and
Installed log..
Thanks-
Afroz
