01-25-2005 01:18 AM
My Campus Mgr is unable to display VPN concentrator connection to my core switch. I suspect it is due to cdp issue on the concentrator. Anyone have any idea?
01-31-2005 07:12 AM
Not sure which version you are using, VPN 3XXX are not supported by Campus Manager 3.1 and following Switch Probes are supported by Campus Manager 3.1 Topology:
LAN SwitchProbes -> Ethernet, Token Ring, FDDI, Fast Ethernet
WAN SwitchProbes -> FR, ATM, HSSI (Management interface only)
WAN SwitchProbes -> Multi-port WAN
For more information, please refer to the link : http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/sup_dev/dev_spt.htm
01-31-2005 06:17 PM
Thnks for the info.
My LMS can see the Concentrator but is represented by a square box with a question mark in it. Funny.
