Unwanted debug output
jjoensen
On some routers (and I can't see the pattern) I experience a lot of lines like:
Apr 1 12:21:32: IP: tableid=0, s=xxx.xxx.xxx.xxx (FastEthernet0/0.6), d=yyy.yyy.yyy.yyy (FastEthernet0/0.6), routed via FIB
when issuing debug ip packet (det) xxx command. Is there a way to avoid getting that information on the switching path - (There will be problems, if I turn off all fast switching/CEF :-() ?
Thank you /Jesper
b.hsu
Level 5
Level 5
These information are called Time Stamp information. These messages appear in the debug output when we enable the command "service timestamps {debug | log} uptime ". If you want to disable this feature use the no form of the command.
"no service timestamps [debug | log] "
