Upgrade CNR 6.2 to 8.1 : db error
adamalex24
I try to upgrade CNR 6.2 to 8.1. When upgrading from a pre-7.2 cluster to 8.1, a plateform-specific tool cnr_mcdexport is required. This step is ok: I migrate 6.2 to 6.3 and, with the cnr_mcdexport, I extract the data from the MCD database 6.3 that is required to upgrade to 7.2 and later.
But, when I install the 8.1, the installation detects the previous version but it fails. This is an extract from install_cnr_log :
Attempting to update the NDB databases...
Unable to remove log files from 'D:\CNR\NetworkRegistrar\Local\data/ccm/ndb' database(s), error = db_archive: Ignoring log file: logs\log.0000000005: unsupported log version 12
db_archive: Invalid log file: log.0000000005: Invalid argument
db_archive: PANIC: Invalid argument
db_archive: PANIC: DB_RUNRECOVERY: Fatal error, run database recovery
db_archive: open: DB_RUNRECOVERY: Fatal error, run database recovery.
Unable to update the 'D:\CNR\NetworkRegistrar\Local\data/ccm/ndb' database(s), error = db_recover: Ignoring log file: logs\log.0000000005: unsupported log version 12
db_recover: Invalid log file: log.0000000005: Invalid argument
db_recover: PANIC: Invalid argument
db_recover: PANIC: DB_RUNRECOVERY: Fatal error, run database recovery
db_recover: DB_ENV->open: DB_RUNRECOVERY: Fatal error, run database recovery.
Attempting to restore previous Network Registrar installation...
Restoring previous Network Registrar data files...
Finished restoring previous Network Registrar data files.
Restoring previous Network Registrar binary and configuration files...
Finished restoring previous Network Registrar binary and configuration files.
*** Installation Failed - 1 ***
I find no solution, no document on the web about this problem.
Have you some documention or information about this problem?
I thank you in advance.
Alexandre.
0 Replies 0
