Upgrade LMS 2.6 to 4.0
Joris Deprouw
Hi Guys,
Does anyone know the procedure to do an LMS upgrade from 2.6 to 4.0.
We will be needing new hardware so I will do a fresh installation of 4.0. Can I restore a 2.6 backup in LMS 4.0. Or do I have to reconfigure from scratch...
Best Regards,
Joris
Marvin Rhoads
You are in luck - backup from LMS 2.6 and restore onto LMS 4.0 is supported. Please refer to:
http://www.cisco.com/en/US/customer/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/install/guide/dmg.html#wp1195819
for the procedure.
Hope this helps.
