06-28-2011 06:13 AM
Hello all,
we are running LMS 3.1 on an Win 2003 Server and now we have purchased an LMS 4.01. I installed LMS 4.01 on an new Win 2008 R2 Server. Now I want to restore an backup from the LMS 3.1 Server on the new LMS 4.01 Server. But the restore does not start and I get the message:
C:\Program Files (x86)\CSCOpx\bin>perl.exe "c:\Progra~2\CSCOpx\bin\restorebackup
.pl" -gen 0 -d c:\migrate
Restore started at : 2011/06/28 13:50:46
Please see 'C:\PROGRA~2\CSCOpx\log\restorebackup.log' for status.
USER ID is ..................................... : cw-management
OS of the backup archive is..................... : Windows
ERROR: This backup archive version is not supported
This restore program will support only backup archives from
CS3.3 or above
Restore failed. Previous system data may be lost due to failed restore. To avoid
this, perform a successful restore.
Can anyone help me what's wrong? In other discussions I ´read I only have to do an restor on the new Version.
Solved! Go to Solution.
06-28-2011 11:59 AM
The problem is you are restoring into the 4.0 service pack (4.0.1). You can only restore backups from LMS 3.2 in 4.0.1 directly. If the backup was from an older version, you need to install 4.0, restore the 3.1 backup and then move to 4.0.1.
This is covered in the 4.0.1 readme:
06-28-2011 11:59 AM
