Upgraded from LMS2.6 to 3.2 and RMEDbEngine, ConfigMgmtServer, and EssentialsDM will not start
itninja2010
I just upgraded Ciscoworks from LMS2.6 to LMS3.2 and I see in the "System" view that RMEDbEngine, ConfigMgmtServer, and EssentialsDM are down.  I attempted to start the processes from "Process Status" window, but that did not work.   Can anyone let me know how to get these processes started or what is wrong ?
12 Replies 12
AFROJ AHMAD
Try the below steps and let me know how it works :
shutdown dmgtd (net stop crmdmgtd)
then remove ctmregistry* from NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib.
Then, restart dmgtd (net start crmdmgtd)
If above did not work send me the below information :
1.output of pdshow
2.syslog.log
3.ctm_config.txt (location :NMSROOT\MDC\Tomcat\shared\lib)
4.md.properties (NMSROOT\CSCOpx\lib\classpath)
5.Installation.log (c:\)
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Afroj,
I should have mentioned that this is on a Solaris server and not Windows.  I have shut down the dmgtd, deleted the ctmregistry, and restarted dmgtd.  I still have a message that RMEdbEngine process is down.  Since this is Solaris, I am unable to follow your instructions for the output you requested.
Hi ,
Is cisco works Integrated with ACS ?
Kindly send me the below information :
1.output of pdshow ( ./pdshow)
2.syslog.log (location : opt/CSCOpx/log)
3.ctm_config.txt ( /opt/CSCOpx/MDC/TOMCAT/shared/lib)
4.md.properties (/opt/CSCopx/lib/classpath)
Afroj
Afroj,
No, I do not have ACS.
I will send you the info you requested.  Thanks.
md.properties file
# more md.properties
CLASSES=pxdm
BASEDIR=/opt
LC_CTYPE=en_US.ISO8859-1
LC_NUMERIC=en_US.ISO8859-1
LC_TIME=en_US.ISO8859-1
LC_COLLATE=en_US.ISO8859-1
LC_MESSAGES=C
LC_MONETARY=en_US.ISO8859-1
LC_ALL=C
PATH=/sbin:/usr/sbin:/usr/bin:/usr/sadm/install/bin
OAMBASE=/usr/sadm/sysadm
PRODNAME=CiscoWorks Common Services
VERSION=3.9
PATCHVER=0
ARCH=sparc
CATEGORY=application
DESC=CiscoWorks Process management commands and interfaces
EMAIL=tac@cisco.com
HOTLINE=1-800-553-6387
PKG=CSCOmd
PKGOWNER=NMCihF78oLBcwNg
PRODVERS=unassigned
VENDOR=Cisco Systems, Inc
NAME=CiscoWorks Process Management package
ALIAS=dmgt CSCOmd
BUILD_ID=SOL_CS33_20090528_2240_protopackage
BUILD_NUMBER=536
PSTAMP=nmch-build-sol28-00420090529065505
PKGINST=CSCOmd
PKGSAV=/var/sadm/pkg/CSCOmd/save
UPDATE=yes
INSTDATE=Jul 01 2011 20:52
DMGT_PORT=42340
DMGT_START=
NMSROOT=/opt/CSCOpx
HOME=/opt/CSCOpx
CWMIBDIR=/opt/CSCOpx/objects/share/mibs
PX_DMGTHOST=127.0.0.1:42340
JAVA_HOME=/u000/lib/jre
LANG=C
NLSPATH=/opt/CSCOpx/objects/share/nls/C/%N.cat
SQLANY10=/opt/CSCOpx/objects/db
ASANY=/opt/CSCOpx/objects/db
SATMP=/var/adm/CSCOpx/files/.SQLAnywhere
ASTMP=/var/adm/CSCOpx/files/.SQLAnywhere
PX_BINDIR=/opt/CSCOpx/bin
PX_DATADIR=/var/adm/CSCOpx/files
PX_DATASTORE=dsn
PX_APPDIR=/opt/CSCOpx/objects
PX_LIBDIR=/opt/CSCOpx/lib
PX_CONFDIR=/opt/CSCOpx/conf
PX_HLPDIR=/opt/CSCOpx/help
PX_DOCDIR=/opt/CSCOpx/htdocs
PX_CGIDIR=/opt/CSCOpx/cgi-bin
PX_LOGDIR=/var/adm/CSCOpx/log
PX_LOGFILE=/var/adm/CSCOpx/log/dmgtd.log
PX_CTRBDIR=/opt/CSCOpx/contrib
PX_FACILITY=local0
PX_TMPDIR=/tmp
I_MODE=UPGRADE
I_CONF_SYSLOG=YES
OSAGENT_PORT=42342
CORE_SECURE_PORT=443
CORE_NONSECURE_PORT=1741
PX_OSA_PORT=42342
PX_JRN_PORT=42343
PX_DMGT_PORT=42340
SVC_ENTRY_WEB=cscoapch
SVC_ENTRY_OSA=cscoosa
SVC_ENTRY_JRN=
SVC_ENTRY_DMGT=cscomd
SVC_ENTRY_SSL=cscoapch_ssl
PX_CLASSDIR=/u000/www/classpath
PX_SCLASSDIR=/u000/lib/classpath
PX_CGIURL=/cgi-bin
PX_DOCURL=/
PX_CLASSURL=/CSCOnm/classpath
PX_HOST=sun1611
PX_FQDN=sun1611.DaytonOH.NCR.COM
PX_USER=casuser
PX_GROUP=casusers
ODBCINI=/opt/CSCOpx/.odbc.ini
PX_DBVIEWUSER=lmsdatafeed
CLASSPATH=/u000/lib/classpath:/u000/www/classpath:/opt/CSCOpx/campus/lib/classpath:/opt/CSCOpx/campus/www/classpath
PX_ANI_PORT=42344
LD_LIBRARY_PATH=/u000/MDC/Apache/lib:/u000/objects/db/lib64:/u000/objects/db/lib32:/u000/objects/db/lib:/u000/lib:/opt/CSCOpx/MDC/lib:/opt/CSCOpx/campus/lib
MAX_RAM=1024
MAX_SWAP=4096
SYS_NO_OF_CPUS=2
TZ=US/Eastern
PX_PORT=443
PX_WEB_PORT=443
PX_PROTOCOL=https
SYS_RAM=8192
SYS_SWAP=23472816
SYS_CPU=1503
1503
ct_config  file
# more /u000/MDC/tomcat/shared/lib/ctm_config.txt
#SERVER_PORT - Ports will be used in ascending order, starting from this port
#Please use unique ports. Port 40000 is simply given as an example and it may
#be used by other applications. Document the ports that are used by your applications
#in respective application documents.
MAX_VM_PORTS=20
#ThreadPool
#MIN_THREADS=3
MAX_THREADS=100
#CTM URL, for tomcat it will usually be be :8080/ctm/CTMServlet
#for Jrun it will usually be :1741/CSCOnm/servlet/com.cisco.nm.xms.ctm.server.CTMServlet"
# for any others it could take any value
#CTM_FileUpload_URL, for tomcat it will usually be be :8080/ctm/FileUpload
#for Jrun it will usually be :1741/CSCOnm/servlet/com.cisco.nm.xms.ctm.server.FileUpload"
#CTM_FileDownload_URL, for tomcat it will usually be be :8080/ctm/FileDownload
#for Jrun it will usually be :1741/CSCOnm/servlet/com.cisco.nm.xms.ctm.server.FileDownload"
CTM_SSL=1
CTM_URL=:443/cwhp/CTMServlet
MAX_VM_CLIENT_CONNECTION=25
#SECURITY_WRAPPER=com.cisco.nm.xms.ctm.security.CMFSecurityWrapper
##REG_LOC_HERE
SERVER_PORT=40050
REGISTRY_LOCATION=/opt/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib
MAX_VM_PORTS=20
#ThreadPool
#MIN_THREADS=3
MAX_THREADS=100
CTM_SSL=1
##REG_LOC_HERE
SERVER_PORT=40050
pdshow file
# ./pdshow
        Process= ESS
        State  = Program started - No mgt msgs received
        Pid    = 14272
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:38
        Stop   = Not applicable
        Core   = Not applicable
        Info   = Application started by administrator request.
        Process= EssMonitor
        State  = Running normally
        Pid    = 14273
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:42
        Info   = ESS is fully up now !
        Process= EventFramework
        Pid    = 14284
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:48
        Process= SyslogCollector
        Pid    = 14285
        RC     = 0
        Signo  = 0
        Process= UPMDbEngine
        Pid    = 14286
        RC     = 0
        Signo  = 0
        Process= UPMDbMonitor
        Pid    = 14296
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:52
        Info   = DbMonitor Running Normally.
        Process= IpmDbEngine
        Pid    = 14297
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:53
        Process= DFMLogServer
        Pid    = 14307
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:30:57
        Process= DFMCTMStartup
        State  = Administrator has shut down this server
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:36:07
        Stop   = 07/05/11 14:36:10
        Process= FHPurgeTask
        State  = Transient terminated
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 07/06/11 00:00:01
        Stop   = 07/06/11 00:00:06
        Info   = DPS Task FHPurgeTask completed at Wed Jul 06 00:00:05 EDT 2011. For status check Job Browser UI.
        Process= DfmBroker
        Pid    = 14309
        RC     = 0
        Signo  = 0
        Process= DfmServer
        Pid    = 14337
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:01
        Info   = DfmServer initialized OK.
        Process= DfmServer1
        Pid    = 14338
        RC     = 0
        Signo  = 0
        Info   = DfmServer1 initialized OK.
        Process= FHDbEngine
        Pid    = 14347
        RC     = 0
        Signo  = 0
        Process= INVDbEngine
        Pid    = 14417
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:06
        Process= PMServer
        Pid    = 14427
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:10
        Info   = PMServer is up and running
        Process= EPMDbEngine
        Pid    = 14428
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:14
        Process= EPMServer
        Pid    = 14438
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:18
        Info   = EPMServer is up and running
        Process= AdapterServer
        Pid    = 14439
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:22
        Process= AdapterServer1
        Pid    = 14440
        RC     = 0
        Signo  = 0
        Process= FHServer
        Pid    = 14441
        RC     = 0
        Signo  = 0
        Info   = FHServer started.
        Process= DFMMultiProcLogger
        Pid    = 14442
        RC     = 0
        Signo  = 0
        Process= ANIDbEngine
        Pid    = 14443
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:23
        Process= MACUHIC
        Pid    = 14454
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:27
        Info   = Started.
        Process= UTLITE
        Pid    = 14455
        RC     = 0
        Signo  = 0
        Info   = Started.
        Process= WlseUHIC
        Pid    = 14456
        RC     = 0
        Signo  = 0
        Info   = Started.
        Process= VNMServer
        Pid    = 14457
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:28
        Process= RMEDbEngine
        Pid    = 0
        RC     = 2
        Signo  = 0
        Stop   = 07/05/11 14:36:09
        Process= OpsxmlDbEngine
        Pid    = 14469
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:32
        Process= CSDiscovery
        State  = Never started
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Info   = Not applicable,
        Process= DCRDevicePoll
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= CSRegistryServer
        Pid    = 14479
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:36
        Info   = CSRegistryServer is running
        Process= Tomcat
        Pid    = 14480
        RC     = 0
        Signo  = 0
        Process= TomcatMonitor
        Pid    = 14501
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:31:40
        Info   = Tomcat Server up
        Process= Apache
        Pid    = 14523
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:33:42
        Info   = Web Server initialized ok.
        Process= LicenseServer
        Pid    = 14524
        RC     = 0
        Signo  = 0
        Process= FDRewinder
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= NameServer
        Pid    = 14525
        RC     = 0
        Signo  = 0
        Process= NameServiceMonitor
        Pid    = 14537
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:33:46
        Info   = NameServer is fully up now !
        Process= EDS
        Pid    = 14541
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:33:50
        Info   = Initialization complete
        Process= ANIServer
        State  = Running with busy flag set
        Pid    = 14778
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:15
        Info   = ANIServer started.
        Process= UTMajorAcquisition
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 07/06/11 09:43:07
        Stop   = 07/06/11 09:58:27
        Process= CmfDbEngine
        Pid    = 14779
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:19
        Process= CmfDbMonitor
        Pid    = 14789
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:23
        Process= DCRServer
        Pid    = 14790
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:24
        Info   = DCRServer is up and running
        Process= CMFOGSServer
        Pid    = 14798
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:33
        Process= CampusOGSServer
        Pid    = 14799
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:37
        Process= EssentialsDM
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= RMEOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= PMCOGSServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ICServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ConfigMgmtServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= UTManager
        Pid    = 14800
        RC     = 0
        Signo  = 0
        Info   = Started.
        Process= TISServer
        Pid    = 14801
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:38
        Process= DFMOGSServer
        Pid    = 14802
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:42
        Process= NOSServer
        Pid    = 14803
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:46
        Info   = NOSServer is up and running
        Process= PTMServer
        Pid    = 14804
        RC     = 0
        Signo  = 0
        Info   = Started Successfully
        Process= InventoryCollector
        Pid    = 14805
        RC     = 0
        Signo  = 0
        Info   = InventoryCollector is up and running
        Process= Interactor
        Pid    = 14806
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:50
        Process= InventoryCollector1
        Pid    = 14807
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:51
        Process= Interactor1
        Pid    = 14808
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:34:55
        Process= UPMProcess
        Pid    = 14809
        RC     = 0
        Signo  = 0
        Info   = UPMProcess started successfully.
        Process= EDS-GCF
        Pid    = 14810
        RC     = 0
        Signo  = 0
        Info   = GCF Initialization complete at Tue Jul 05 14:35:25 EDT 2011
        Process= jrm
        Pid    = 14811
        RC     = 0
        Signo  = 0
        Process= 3437
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= CTMJrmServer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= ChangeAudit
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= SyslogAnalyzer
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = N/A
        Process= DataPurge
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:35:20
        Stop   = 07/05/11 14:36:22
        Info   = DataPurge initialization completed at Tue Jul 05 14:36:21 EDT 2011.
        Process= IPMProcess
        Pid    = 14813
        RC     = 0
        Signo  = 0
        Process= IPMOGSServer
        Pid    = 14816
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:35:24
        Process= diskWatcher
        Pid    = 14817
        RC     = 0
        Signo  = 0
        Info   = diskWatcher initialized OK.
        Process= ProcSysBus
        Pid    = 14818
        RC     = 0
        Signo  = 0
        Process= OpsXMLRuntime
        Pid    = 14827
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:35:28
        Process= CWAPublisher
        Pid    = 0
        RC     = 0
        Signo  = 0
        Start  = 07/05/11 14:35:32
        Stop   = 07/05/11 14:38:51
CTMJrmServer is down and this is the problem.
kindly send me the below info:
CTMJrmServer.log
jrm.log
Jrm_user.properties file
If possible (syslog_info)
Afroj
Afroj,
Here is the relevant output from the CTMJrmServer.log
[ Mon Jun 27  02:05:04 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,117,getJRM:  bind successful
[ Mon Jun 27  02:06:00 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,251,getJRM: SUCCESSFUL CONNECTION TO JRM.
[ Mon Jun 27  02:06:01 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,,71,Published URN: JRM
[ Mon Jun 27  02:06:01 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,97,Publishing daemon ok
[ Mon Jun 27  02:06:01 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,99,Called CreateReady file. Return Va
lue 0
[ Tue Jun 28  09:12:39 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for jrmw-log
[ Tue Jun 28  09:12:40 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as jrmw-log-RMELogLev
elChange
[ Tue Jun 28  09:12:47 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,117,getJRM:  bind successful
[ Tue Jun 28  09:13:45 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,251,getJRM: SUCCESSFUL CONNECTION TO JRM.
[ Tue Jun 28  09:13:46 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,,71,Published URN: JRM
[ Tue Jun 28  09:13:46 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,97,Publishing daemon ok
[ Tue Jun 28  09:13:46 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,99,Called CreateReady file. Return Va
lue 0
[ Tue Jun 28  09:21:15 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for jrmw-log
[ Tue Jun 28  09:21:17 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as jrmw-log-RMELogLev
elChange
[ Tue Jun 28  09:21:24 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,117,getJRM:  bind successful
[ Tue Jun 28  09:22:23 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,251,getJRM: SUCCESSFUL CONNECTION TO JRM.
[ Tue Jun 28  09:22:24 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,,71,Published URN: JRM
[ Tue Jun 28  09:22:24 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,97,Publishing daemon ok
[ Tue Jun 28  09:22:24 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,99,Called CreateReady file. Return Va
lue 0
[ Fri Jul 01  15:04:33 EDT 2011 ],INFO ,[CTMJrmServer],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,shutdown,113,shutting down CTMJrmServer
[ Sat Jul 02  22:53:03 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for jrmw-log
[ Sat Jul 02  22:53:03 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as jrmw-log-RMELogLev
elChange
[ Sat Jul 02  22:53:06 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,249,getJRM:  bind successful
[ Sat Jul 02  22:53:06 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,383,getJRM: SUCCESSFUL CONNECTION TO JRM.
[ Sat Jul 02  22:53:06 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,,71,Published URN: JRM
[ Sat Jul 02  22:53:06 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,97,Publishing daemon ok
[ Sat Jul 02  22:53:06 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,99,Called CreateReady file. Return Va
lue 0
[ Sun Jul 03  23:08:54 EDT 2011 ],INFO ,[CTMJrmServer],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,shutdown,113,shutting down CTMJrmServer
[ Wed Jul 06  15:18:51 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,35,publishing urn for jrmw-log
[ Wed Jul 06  15:18:52 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.util.logger.ServiceLogLevelChanger,notifyLevelChange,42,published urn as jrmw-log-RMELogLev
elChange
[ Wed Jul 06  15:18:54 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,249,getJRM:  bind successful
[ Wed Jul 06  15:18:54 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.JobManagerExt,getJRM,383,getJRM: SUCCESSFUL CONNECTION TO JRM.
[ Wed Jul 06  15:18:54 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,,71,Published URN: JRM
[ Wed Jul 06  15:18:54 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,97,Publishing daemon ok
[ Wed Jul 06  15:18:54 EDT 2011 ],INFO ,[main],com.cisco.nm.rmeng.jrmwrapper.server.CTMJobManagerServer,publishDaemonOk,99,Called CreateReady file. Return Va
lue 0
Afroj,
I am unable to find the jrm.log file and the Jrm_user.properties file on my server.  The syslog_info file contains the syslog messages received from our network devices.  Are there any other files you need?  Thanks.
kindly look for the file
jrmuser.properties ( location:/opt/CSCOpx/lib/classpath)
and check the ServiceName present in jrmuser.properties. It should only include the hostname not the FQDN.
If you found FQDN in the properties file change it and Re-start the Daemon Manager.
Afroj
Hello Afroj,
I checked the jrmuser.properties file and it does not have the FQDN.  Here is the output below.  Any other suggestions for me ?  Thanks.
# more jrmuser.properties
#Configure the username to pass for Jobcli and Lockcli
#Sat Jul 02 02:41:19 EDT 2011
Username=admin
ServiceName=JrmServiceManager_sun1611
