Uptime report using CWLMS 3.2
Douglas Barboza
Is it possible to run an uptime report using CWLMS 3.2 ?
Thanks for your comments,
Martin Ermel
Resource Manager Essentials > Reports > Custom Report Templates
    choose  "Inventory" as the report type
choose "System" and "SysUpTime" as the field to be added;
when done, you can use this template under
RME > Reports > Report Generator > Inventory Report and select your template to generate the report
Details can be found here:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/invent.html#wp1258992
Thanks for your comment...
One more question,
Can I obtain an uptime report from an especific interface (fisical or tunnel) ?
