using an alias for ssh
joshuahurley
Community Member
I am currently trying to use an alias so i can type hostname in to ssh instead of remembering IP address. Does anyone know how to input this in a switch 9300. I have tried alias exec ssh (ip address) (hostname) and it does not work any help would be really appreciated.
Mark Elsen
          - Make sure that the hostname can be resolved by DNS on the switch ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
 If you have "ip domain name"  and "ip domain lookup" on the device you should be able to access using ssh -l "user" device.domain
I would say alias is more suitable to hide a command or a group of command in one word.
mmohammed
Level 2
Level 2
To configure an alias for SSH access on a Cisco Catalyst 9300 switch, you need to use the ip host command. Here's the correct syntax:
ip host <hostname> <ip-address>
Replace <hostname> with the desired alias or hostname and <ip-address> with the corresponding IP address. Here's an example:
Switch(config)# ip host myswitch 192.168.1.100
This configuration will create an alias called "myswitch" for the IP address 192.168.1.100. Once configured, you can use the alias instead of the IP address when connecting via SSH.
To establish an SSH connection using the configured alias, you can simply type:
ssh <hostname>
In this example, it would be:
ssh myswitch
Make sure you save the configuration using the write  command to ensure the alias persists after a reboot.
If you're still encountering issues, please provide more details or error messages for further assistance.
