Using Loopback Interfaces for management connectivity
makkers
Level 2
Level 2
I am struggling to really understand how to use a Loopback interface for management purposes on my Cat4507 switches and looking for any guidance.
I have 4 x 4507's 2 for aggregation(L3) and 2 for access layer (L2). There are 6 vlans doing the L3 thing and default vlan 1 is not used.
If I assign a loopback interface with a 32bit mask I cannot ping it from any other switch.
Really I do not want to manage the switches for Cworks or Openview telnet etc on one of the vlan IP addresses.
Am I missing the point here somewhere?
Any advice / guidance much appreciated.
5 Replies 5
lgijssel
Level 11
Level 11
The following questions might help you on your way:
In which ip range did you configure the loopbacks?
Are you using a routing protocol that can handle vlsm to advertise these host routes?
Have you setup ip routing correctly for this subnet?
It must be a config error, we have been using this setup also and it works.
Leo
steve.busby
Level 10
Level 10
Are you adding the loopback ip address to your routing protocol?
The only way other boxes are going to know about the loopback address is if you advertise it out someway.
As far as management from CW2K goes, the later releases RME3.4+ have a much better mechanism to determine the correct management IP (loopback in your case).
No comment on Openview, as it's been a few years since I've used that platform.
Steve
Concerning OpenView, this likes to use the address that is resolved in DNS or a hosts file. If multiple addresses of one device are resolved differently in DNS, the lowest IP address is used. In general the mechanism starts with the lowest IP address and uses the first that can be resolved. Depending on the version of OpenView, there are config file to determine the IP address for SNMP communication.
Martin
Thanks to all for the responses they have been really helpful and got the thought processes going.
To answer some of the questions asked:
The loopback interfaces are configured with a 172.16.1.0 /32 address
Using EIGRP which automaticllly supports vlsm and the range has been added to the routing protocol and is being advertised
I believe that I have set up the routing ok, but could be wrong!
It will be a config / user error as thats what I do!
I have attached a chooped down version of the config below for reference:
Current configuration : 9493 bytes
version 12.2
no service pad
service timestamps debug uptime
service compress-config
hostname Access_02
logging buffered 65536 informational
enable secret 5 [removed]
ip subnet-zero
ip domain-name [removed]
spanning-tree mode rapid-pvst
power dc input 2500
redundancy
mode rpr
main-cpu
auto-sync standard
vlan dot1q tag native
interface Loopback0
ip address 172.16.1.4 255.255.255.255
interface GigabitEthernet1/1
description To Aggregation_01 Port 7/1
switchport mode dynamic desirable
logging event link-status
udld port aggressive
! [All ports removed]
interface GigabitEthernet7/18
shutdown
interface Vlan1
no ip address
interface Vlan136
no ip address
interface Vlan137
no ip address
interface Vlan138
no ip address
interface Vlan139
no ip address
interface Vlan140
ip address 155.111.111.111 255.255.255.0 [phoney]
interface Vlan141
no ip address
router eigrp 100
network 155.111.0.0
network 172.16.1.0 0.0.0.0
auto-summary
ip classless
no ip http server
snmp-server community [removed] RO
snmp-server community [removed] RW
snmp-server enable traps tty
banner exec ^C
[removed]
Unfortunately you are correct about there being a configuratin error. Under router eigrp 100 you specify network 172.16.1.0 0.0.0.0 and this mask indicates that you are looking for host address 172.16.1.0. But the address on the loopback is 172.16.1.4 so it does not match. You can correct this either by changing the mask in the network statement network 172.16.1.0 0.0.0.255 or you can change the address in the network statement network 172.16.1.4 0.0.0.0. Either of these should make it work.
Rick
Rick
