Using PI 2.1 to "push" Jumbo Frame MTU setting?
cburnham
Level 4
Level 4
HI,
We are trying to leverage PI 2.1 to push "mtu jumbo 9000" to several hundred of our switches (2960 (G,S & X models), 3750 models, as part of a large MTU project.  We can't seem to find this function in the template library.  We are struggling with using Velocity Template Language (VTL) to author such command.  We are unfamiliar with this language. It is not in the manual from the official Cisco PINFRA training class we just took.
Anyone out there know what I am  talking about?
Chad
7 Replies 7
Marvin Rhoads
Just use the basic cli template and send the one command you need to the devices that need it.
Thanks Marvin, you are always so fast and helpful on this forum!  I'll let Mike on my team try this and report back!
Marvin
Using the basic cli template and a single command to a single switch worked. However I need to run a couple of commands to multiple switches like;
1) system mtu jumbo 9000
2) copy running-config startup-config
3) reload
Mike
A cli template can be comprised of multiple commands.
You only need to use the VTL scripting if you want to get fancy and use forms etc.
I have been unsuccessful thus far. I will continue to read and peck away at getting multiple commands i.e. configuration and enable commands to work together in the same cli template.
Here's a cli template (sanitized a bit) I have in place on a network. Remember your commands are config-mode so anything that you need to execute in enable mode needs to be prepended with "do".
service sequence-numbers
logging host 10.0.*.*
snmp-server host 10.0.*.* ****private
no ip ssh logging events
errdisable recovery cause all
udld enable
do copy running-config startup-config
It works very nicely. and you should be able to lay out any arbitrary set of valid commands similarly. I have set validation criteria to only allow it to go to devices for which these are valid commands (although you could easily choose only valid devices during the deployment process).
Mike,
Something else that can be done is to set up composite templates for multiple commands to be run.  With composite templates, Prime still somewhat "acts" like it is driving out each command separately, but it will help free you up from either:
1. running multiple jobs to get your configs rolled out
2. free you up from having to employ using some of the Apache VTL scripting
Although, in referencing this particular link of PI documentation, they do show some helpful syntax on how to script multi-line configs.
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/user/guide/prime_infra_ug/create_temps.html#31705
Here is a sample that I extracted from some of Cisco's docs using VTL.
#MODE_ENABLE
write memory
#MODE_END_ENABLE
here is a sample of employing banner messages using the multi-line command:
<MLTCMD>banner login ^C
enter applicable text here...
^C</MLTCMD>
<MLTCMD>banner motd ^C
enter applicaple text here...
^C</MLTCMD>
<MLTCMD>banner exec ^C
 Enter applicaple text here...                                         -
^C</MLTCMD>
HTH....
Brandon
