Bookmark
Subscribe
7093
Using SNMP traps to trigger EEM Applets
jschweng
We need to be able to change the allowable line rate going into a switch from a Linux Mgt Server using snmp.   Was trying to use EEM applets which would be triggered via snmp traps from the server. We need to change it up to ten different rates.  I can't seem to get the applets to trigger.   Any help would be appreciated - thanks.
class-map match-all CLASS_SLAP
match access-group name ACL_SLAP
policy-map OCA-RATE-LIMIT
class CLASS_SLAP
  police 1900000 100000 exceed-action drop
interface GigabitEthernet1/0/20
switchport access vlan 10
switchport mode access
speed 100
duplex full
service-policy input OCA-RATE-LIMIT
snmp-server community <removed> RO 98
snmp-server community <removed> RW 99
snmp-server host <IP> version 2c <removed>  snmp
snmp-server host <IP>version 2c <removed>
snmp-server manager
event manager applet OCA-limit-3M
event snmp-object oid 1.9.9.9.3 type gauge sync yes istable no
action 1.0 cli command "enable"
action 2.0 cli command "config terminal"
action 3.0 cli command "policy-map OCA-RATE-LIMIT"
action 4.0 cli command "class CLASS_SLAP"
action 5.0 cli command " police 3000000 100000 exceed-action drop"
action 6.0 snmp-object-value event-id _event_id gauge 0 next-oid 1.9.9.9.3.0
action 7.0 exit 1
event manager applet OCA-limit-6M
event snmp-object oid 1.9.9.9.6 type gauge sync yes istable no
action 5.0 cli command " police 6000000 100000 exceed-action drop"
action 6.0 snmp-object-value event-id _event_id gauge 0 next-oid 1.9.9.9.26.0
action 7.0 exit 1
event manager applet OCA-limit-7M
event snmp-object oid 1.9.9.9.7 type gauge sync yes istable no
action 5.0 cli command " police 7000000 100000 exceed-action drop"
action 6.0 snmp-object-value event-id _event_id gauge 0 next-oid 1.9.9.9.7.0
action 7.0 exit 1
event manager applet OCA-limit-8M
action 5.0 cli command " police 8000000 100000 exceed-action drop"
action 6.0 snmp-object-value event-id _event_id gauge 0 next-oid 1.9.9.9.8.0
action 7.0 exit 1
event manager applet TESTTEST
event none
action 5.0 cli command " police 1900000 100000 exceed-action drop"
action 7.0 exit 1
end
34 Replies 34
Chokes how?  This should (and does) work.  The value of the _cli_result variable will always hold the output of the last CLI command executed.
I think I got the $_cli_result to work.  I was trying to trigger it with an applet that has event none.  I had to use the trigger that is "event none sync yes" then it worked.   I'm not sure what "sync yes" does but it must be important.
Things are looking good.  One things that';s come is the users are complaining about poor network performance.   I checked the CPU on my switch that is runngin eem and whenever I send it a few triggers in a row the CPU pegs to 100%.   with no debug going.  My code follows.
My questions are :
     1.  Is that normal
     2.  Should I use some other oid value.  I ran snmp debug packets and I see alot status information in the log file.  Is there some benign generic oid that I should use to trigger the event rather than what I am?
     event snmp-notification oid 1.9.9.9. oid-value "3M" op eq
     ... more commands ...
     action 7.0 exit 1
snmptrap -v 2c readme -Ci    ""  1.9.9.9 1.9.9.9.9.0  s "3M"
Thank you for the help
Jeff
The $_cli_result variable does not depend on the event detector.  You just need to make sure you perform at least one action cli before dereferencing the variable.
You should remove the action 7.0 line.  You don't need to exit with a failure.
As for the high CPU, without seeing which process is causing this, or seeing the "show stack" output for that process, I cannot comment.
ok thanks - my switch is a lab switch so all its doing is EEM right now.   I think probably the CPU is caused by which trap I am sending it from my host.  When I debug snding trap 1.9.9.9.0 I get all this in my log.   I've read where when sending traps to trigger events it really does't matter what MIB you use, but it seems to cause the swtich to process alot of data.  Is there any totally generic MIB I could use that would not do anything mor ethan trigger the event?
#event manager run TESTTEST
3M
3000000
MCCB8SW#
00:52:39: SNMP: Queuing packet to 10.10.108.101
00:52:39: SNMP: V2 Trap, reqid 23, errstat 0, erridx 0
sysUpTime.0 = 315992
snmpTrapOID.0 = cEventMgrMIB.0.2
ceemHistoryEventEntry.2.13 = 131
ceemHistoryEventEntry.3.13 = 0
ceemHistoryEventEntry.4.13 = 0
ceemHistoryEventEntry.5.13 = 0
ceemHistoryEventEntry.6.13 =
ceemHistoryEventEntry.7.13 = applet: TESTTEST
ceemHistoryEventEntry.9.13 = 0
ceemHistoryEventEntry.10.13 = 0
ceemHistoryEventEntry.11.13 = 3M
ceemHistoryEventEntry.13.13 = 0
ceemHistoryEventEntry.14.13 = 0
ceemHistoryEventEntry.15.13 = 0
ceemHistoryEventEntry.16.13 = 0
00:52:39: SNMP: Queuing packet to 160.108.10.111
00:52:39: SNMP: V1 Trap, ent cEventMgrMIB, addr 160.108.10.1, gentrap 6, spectrap 2
00:52:40: SNMP: Queuing packet to 10.10.108.101
00:52:40: SNMP: V2 Trap, reqid 25, errstat 0, erridx 0
sysUpTime.0 = 316006
ceemHistoryEventEntry.2.14 = 131
ceemHistoryEventEntry.3.14 = 0
ceemHistoryEventEntry.4.14 = 0
ceemHistoryEventEntry.5.14 = 0
ceemHistoryEventEntry.6.14 =
ceemHistoryEventEntry.7.14 = applet: TESTTEST
ceemHistoryEventEntry.9.14 = 0
ceemHistoryEventEntry.10.14 = 0
ceemHistoryEventEntry.11.14 = 3000000
ceemHistoryEventEntry.13.14 = 0
ceemHistoryEventEntry.14.14 = 0
ceemHistoryEventEntry.15.14 = 0
ceemHistoryEventEntry.16.14 = 0
00:52:40: SNMP: Queuing packet to 160.108.10.111
00:52:40: SNMP: V1 Trap, ent cEventMgrMIB, addr 160.108.10.1, gentrap 6, spectrap 2
I was trying to parse the output of "show polic-map | i police"  so that I can put the rate in a variable and send it off as a trap.   In this case it would be 6MegB.  Actions 6.2, 6.3, 6,4, 6.5 were supposet o do that - but no joy. Any idea on what is wrong with the syntax. It just needs to pick out the first 7 to 8 digits.
event none sync yes
action 5.1 cli command "exit"
action 6.0 puts "6M"
action 6.1 snmp-trap intdata1 6000000 strdata ""
action 6.2 cli command "show policy-map | i police"
action 6.3 regexp " [0-9] " "$_cli_result" result
action 6.4 puts "$_cli_result"
action 6.5 snmp-trap strdata "$result"
You want:
action 6.3 regexp "([0-9]+)" "$_cli_result" result
This is coming from outgoing EEM traps.  It doesn't matter what trap you send to the device.  A generic one wouldn't have any different effect from a customized one.
In this case, it looks like you have multiple trap hosts defined, and all of them are receiving the EEM traps (i.e. you do not have additional trap keywords on them to limit the trap types they receive).
In order to get to the root of the CPU problem, you would need to provide the output of "show proc cpu sorted" when the CPU is pegged.
ok thank - I tried that exact thing. It always chokes on line 6.4. If I take out 6.4 it chokes on 6.5.  Here is script and output.
event none sync yes
action 6.4 puts "$result"
#event manager run OCA-limit-6M
#6M
router#
00:06:40: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment variable: result
00:06:40: %HA_EM-3-FMPD_ERROR: Error executing applet OCA-limit-6M statement 6.
Post the full output of "show policy-map | i police".
The first number will be either 3,6, 7,8,10, 12, 18, 20,,22,24,25 Meg.   So it could be 7 or 8 digits.
router#show policy-map | i police
router#
This works for me:
event none sync yes
action 5.1 cli command "end"
action 6.3 regexp "police ([0-9]+)" $_cli_result whole result
Note: you had an "exit" in there where you needed to have an "end".
Any idea if thsi book is giong to be any good.  or do you know any others that have details on EEM and TCL scripting as applied to cisco. I've got a feeling I'm going to need some references.
TcL Scripting for Cisco IOS (Networking Technology) [Paperback]
Raymond Blair (Author), Arvind Durai (Author), John Lautmann (Author)
I was one of the technical editors of this book, and it will be quite useful to people wanting to learn Tcl on IOS.  It does cover some EEM examples as well, but not much in the realm of applets.
ok thanks - I entered the code as shown for hte 6M. The first two times i tried it I got the same errors. Then it worked.  So I added same action 6 code to the 3M segment - no joy there. same errors.  Do I have to initialize the variable "result" or something.
router#event manager run OCA-limit-6M
6M
6000000
router#event manager run OCA-limit-3M
3M
router#
00:48:03: %HA_EM-3-FMPD_UNKNOWN_ENV: fh_parse_var: could not find environment va
riable: result
00:48:03: %HA_EM-3-FMPD_ERROR: Error executing applet OCA-limit-3M statement 6.
event none sync yes
action 6.0 puts "3M"
action 6.1 snmp-trap intdata1 3000000 strdata ""
action 6.3 regexp "police ([0-9]+)" "$_cli_result" whole result
action 9.0 exit 1
event none sync yes
action 9.0 exit 1
Joe - I think tis working. You're right I have an "exit" and needed an "end" . Didn't have t
hat inthe 3M segment. Seems to work ok. I'm outof you.
Thanks for all your help - will probably have to ask you somestuff about het high cpu next week.
have a great weekend
Jeffrey Watson
Lockheed Martin
