USXGMII specification EDCS-1467841 revision 1.4
youcisco
Beginner
Beginner
Is it possible to have the USXGMII specification, and any technical description.
Georg Pauwen
VIP Master VIP Master
VIP Master
not sure if this helps:
https://developer.cisco.com/site/usgmii-usxgmii/
Thanks Georg for the answer but in this page we only have the USGMII spec and not the USXGMII
I was afraid that would not be of much use. I basically did a blind Google search...
It seems there is little to none information available, all I get is very short specs like the one linked below:
https://www.intel.com/content/www/us/en/docs/programmable/720989/22-2-20-1-0/usxgmii.html
EDIT: I might as well post the PDF files I found...
Hi Georg,
That's all about I found too, thanks anyways for your help.
Recognize Your Peers
