UTU 2.0 with LMS4.0.1
mmisonne
Level 2
Level 2
Hello
I cannot get reponse from lms4.0.1 with my client UTU2.0
I allways receive "No Records Found"
With a  wallchart, here is the response I recieve from LMS
]....... .c....P...i+..HTTP/1.1 200 OK..Date: Tue,24 May 2011 15:19:20 GMT..
Server: Apache..Content-Leng th:53..Cache-Control: max-age=3 00..
Expires: Tue ,24 May 2011 15:24:20 GMT..Vary : User-Agent..Connection: close. .
Content-Type: text/plain;charse t=ISO-8859-1.... <?xml version="1 .0" standalone=" yes" ?> <UTU></U TU>..
Could you please help me.
Michel Misonne
Marvin Rhoads
Have you checked that you are doing the right search type for the query you are submitting?
UTU will default to the last used query type. Right-click in the search box to see the type you are running.
Marvin Rhoads
OK.
When I typed the complete Mac-address, it works.
If I type only  a star (*), I though it will give all the Mac-adddress, but in fact it didn't
Michel misonne
