Verifying Syslog automated actions
gautamzone
Dear friends,
I have some sylog messages on which i am defining an automated action. I just want to make sure that they are right.
The syslog messages that i want to try are:
1. %BGP-5-ADJCHANGE
2. %BGP-3-NOTIFICATION
Can you tell me if my settings under RME-->Tools-->Syslog-->Automated action is right?
Facility: BGP
Sub-facility: *
Seveirity : *
Mnemonic: ADJCHANGE ,NOTIFICATION
Thanks a lot
Gautam
luijimen
Hi Gautam,
You almost nailed it. Try the following settings instead:
Facility: BGP
Subfacility: *
Severity: 5
Mnemonic: ADJCHANG
Description:*
Facility: BGP
Subfacility: *
Severity: 3
Mnemonic: NOTIFICATION
Description:*
You will need to create 2 separate lines, one for each syslog message type. The above should match the same messages you mentioned.
Luis.
luijimen
Hi Gautam,
Facility: BGP
Subfacility: *
Severity: 5
Mnemonic: ADJCHANG
Description:*
Facility: BGP
Subfacility: *
Severity: 3
Description:*
Luis.
Thanks a lot Luis for your wonderful support.
Thanks and Regards
Gautam
