VLAN error
handsome
May i ask what is happening to my vlans? i tried to configure those 2 vlans which is vlan 10(left) and vlan 20 (right). but they can connect each other even when they are on the different vlan... what is wrong with my configuration?
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
 switchport trunk native vlan 99
 switchport mode trunk
interface FastEthernet0/2
 switchport access vlan 10
 switchport mode access
interface FastEthernet0/3
 switchport access vlan 20
license udi pid CISCO2911/K9 sn FTX1524YU8Y-
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/0.10
 encapsulation dot1Q 10
 ip address 10.10.10.1 255.255.255.248
interface GigabitEthernet0/0.20
 encapsulation dot1Q 20
 ip address 10.10.20.1 255.255.255.248
interface GigabitEthernet0/0.99
 no ip address
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 shutdown
5 Replies 5
balaji.bandi
Please clarify what is the issue ? they can connect or they can not connect VLAN 10 and VLAN 20 ?
what is the IP address of the device ?
BB
they can connect to each other... it should be not connected
this looks like a Packet Tracer project. Post the zipped project (.pkt) file...
if they are not support to contact each other then you need to put ACL to deny.
examples :
https://www.cisco.com/c/en/us/support/docs/ip/access-lists/26448-ACLsamples.html
BB
Deepak Kumar
As per the design and configuration, both VLAN hosts must communicate because you are using a router as a gateway, and Routing is enabled by default on all routers.
So, when you are trying to ping or send traffic from VLAN 10 to 20 or vice versa, Packets reach the gateway (router) and it will route traffic on the required destination VLAN.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
