VLAN interconnection training
joe97
Hi everyone, can anyone help me configure this? I've configured the VLANs on the 2960 switch, but why can't I communicate with other VLANs?
thank you
2 Accepted Solutions
Got it working:
Port needs to be in Access Mode
1.If you want to ping from the switch its needs a Default Gateway and a Management IP
2.Also other Host (End-devices) don't have their IP set other than PC0
core_switch#show run
Building configuration...
Current configuration : 2201 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname core_switch
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 4
switchport trunk allowed vlan 4,16,32-33,65
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 16
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 32
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 33
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 65
interface FastEthernet0/10
switchport mode trunk
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan4
ip address 172.25.4.100 255.255.255.0
ip default-gateway 172.25.4.254
line con 0
line vty 0 4
login
line vty 5 15
login
end
CORE_ROUTER#show run
Current configuration : 1172 bytes
version 15.4
hostname CORE_ROUTER
no ip cef
no ipv6 cef
no ip domain-lookup
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0/0.4
encapsulation dot1Q 4
ip address 172.25.4.254 255.255.255.0
interface GigabitEthernet0/0/0.16
encapsulation dot1Q 16
ip address 172.22.16.254 255.255.255.0
interface GigabitEthernet0/0/0.32
encapsulation dot1Q 32
ip address 172.22.32.254 255.255.255.0
interface GigabitEthernet0/0/0.33
encapsulation dot1Q 33
ip address 172.22.33.254 255.255.255.0
interface GigabitEthernet0/0/0.65
encapsulation dot1Q 65
ip address 172.22.65.254 255.255.255.0
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/2
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router rip
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
12 Replies 12
Enes Simnica
hello. Since ur 2960 is a Layer 2 switch, it can't route between VLANs by itself, even with IPs on interfaces. You need either: 1) A router with subinterfaces (router-on-a-stick), 2) A Layer 3 switch to handle routing, or 3) VLAN interfaces (SVIs) with IPs on a different device that can route. The switch ports can have IPs, but without VLAN interfaces or a router doing the inter-VLAN routing, traffic won't cross VLANs.
but u can share here ur PT topology and I will check that my Cisco friend...
hope it helps and PEACE!
-Enes
more Cisco?!
more Gym?!
If this post solved your problem, kindly mark it as Accepted Solution. Much appreciated!
🤣 my bad sir, yeah... my bad 🤣🤣🤣 i haven't understand yet which layer 3 switch and which layer 2 switch in cisco, yes i'll attach my training.
thank you, thank you
You're likely problem is, (within your PT attachment) interfaces to your hosts are trunk interfaces
Try making them access ports, in the desired host VLANs, and see if it works better.
hello sir, yes... the reason why i made and use trunk is i want each devices in each segments can be communicate. example PC in segment 4(172.25.4.55) can be ping to other segment like PC in segment 16 or 32
Unless your host devices use (the correct) VLAN tags, and most often they don't (except for VoIP phones), they won't exchange frames with a trunk port.
You can have each host within a different VLAN, and, again, their switch ports configured as access ports in the VLAN you desire.  The switch will then exchange those different VLANs with the router, where you (correctly, it appears) have that switch port configured as a trunk and the router port defined with subinterfaces.  The router would transfer frames between the VLANs.
i see, i try using access instead of trunk and it works
u good man DW. If u can send the topology gain, because it opens blank .... SO u need to send the topology as a .pkt
more Cisco?!
more Gym?!
Hi, sorry... i have make the pkt file as zip sir, but i don't know why it's blank
if you don't mind, i attached the topology here
If your trying to configure Router-on-a-stick you need to have the Router configured and the trunk to the router configured correctly too.
Switch:
1. Make sure all Ports on their VLAN are in access mode (swithport mode access)
2. Trunk to the router carring all VLANs (Swithport mode trunk
Router:
1. Gigabit0/0/0 (no ip add & no shut)
2. Gigigbit0/0/0.4 (encapsulation dot1q 4 & ip add 172.125.4.254 255.255.255.0
Got it working:
version 15.0
interface Vlan1
no ip address
shutdown
interface Vlan4
line con 0
line vty 0 4
login
line vty 5 15
login
end
version 15.4
no ip cef
no ipv6 cef
no ip domain-lookup
no ip address
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
interface Vlan1
no ip address
shutdown
router rip
ip classless
line con 0
line aux 0
line vty 0 4
login
end
i have reconfigure it, and yeah.. my mistake not set the switch as access mode, instead trunk to each interface
thank you
