VLAN Port Assignment failed on Campus Manager 5.1
micoogullari
Dear All,
i deploying LMS 3.1  in my organization.
I finalized the installation and  all looks fine BUT   when i try to assign a port to a different VLAN in Campus Manager (5.1)  i am getting the following error message.
There were some errors during operation."
Error occured moving port Gi1/8 in device 10.x.y.z  into vlan with index XY.
Cause:An error occured while performing SNMP operation.
Action:Examine and save the server log file and report the error to the product administrator for further action.
any idea?
here is simply the config  related to SNMP on my switch.
snmp-server community XXXXXXXX
snmp-server host 10.X.Y.Z version 2c XXXXXXXX
snmp-server enable informs
snmp-server enable traps
do i miss anything else?  any recommendation? Why i am getting that error message?
Thank you for your support and asistance.
Kind Regards,
mico
2 Accepted Solutions
Joe Clarke
It looks like you may be missing an SNMP read-write community string.  Campus requires SNMP read-write to be configured on the device (with matching credentials in DCR) to do the VLAN configuration.
where have you set the snmp credentials on the LMS server ?
You need to change them explicitely for an device that is already in DCR. This is one way how to change the credentials:
go to Common Services > Device and Credentials > Device Management
Select the Device and click on "Edit Credentials"
5 Replies 5
Joe Clarke
Hi Joe,
thank you so much for your kind reply. I configured the snmp RW community string on the switch matching the credentials  on the LMS server but still getting the same error message when i try to assign ports no a different VLAN
here is my commands for the switch:
snmp-server community xxxxxx ro
snmp-server community yyyyyy rw
snmp-server host x.y.w.z version 2c yyyyyy
and on the LMS server i set the values:
Start a sniffer trace filtering on all udp/161 traffic between the LMS server and the device.  Then reproduce the problem.  Post the trace file.
micoogullari
Mermel,
thank you so much!!!  on LMS server  i set the snmp credentials on the server setup by using  ciscoworks assistant.
i was facing the problem mentioned before.
As you said i  went to Common Services > Device and Credentials > Device Management
Select the Device and click on "Edit Credentials"    then set snmp RW credentials and now all is working fine. no more error!
Thank you very much for your assistance and support.
