VLAN RUNNING Config fetch Failed
ahmedshoaib
Level 4
Level 4
Hi;
I have running Ciscowork LSM 3.2 with RME Ver 4.3 and Running SNMP V3 on all device. Out of 134 device 12-13 shows me Vlan running Config fetch failed. Please also find the dcmaservice.log in attachment.
I already verify the Crediential number or times, I can access the devices from SSH and Telnet, on Cisco works RME shows Running and Startup Config success while VLAN Running Config fetch failed. and on some device it show following
Protocol and Platforms passed = TELNET , RMEIOS
trying for Telnet
Failed to get CmdSvc from DeviceContext....
Best regards;
Shoaib Ahmed
AFROJ AHMAD
HI Shoaib,
Try  ssh\telnet into the device manually and issue the command copy flash:vlan.dat tftp: and
enter the IP address of the LMS server? Does it work? If that works fine, try to increase
the tftp timeout.
This can be done under RME> Admin> System Preferences> RME Device Attributes.
if it failed with an Error as below :
%Error opening tftp: ............
Then check if there any firewall in between these device and LMS blocking TFTP as TFTP is the only protocal
that fetch the vlan.dat from the device.
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
