VMS Management Center for PIX firewalls install
jason.aarons
Does the Sybase error message indicate there was a problem installing the MC for PIX ?
ERROR: Failed connection to Sybase: Timed out waiting for database server to start
Started : Wed Dec 1 14:53:19 CST 2004
===============- Software Installation Tool Started. -=====================
===- Welcome to the Management Center for Firewalls 1.3.2.18 Setup program.
Press ENTER to read/browse the following License Agreement :
Entered value is
INFO: BUILD_ID is SOL_PIXMC_UNION_CH_20040722_2207
INFO: ITOOLS_BUILD_ID is SOL_ITOOLS2_2_20030414_0016
INFO: This server architecture is 32-bit compatible.
INFO: /tmp directory has 777 permissions.
INFO: /etc/hosts is readable by all.
INFO: OS major is 5 and OS minor is 8
INFO: OS major or minor patch version not set.
INFO: Checking group entry casusers.....
INFO: Group created for installable packages is casusers.
INFO: Checking user entry casuser.....
INFO: casuser for installable packages exists.
INFO: No user added to the system.
INFO: Warning - No PRMOPT_INSTALL_TYPE section in TOC-file.
INFO: Warning - No installation default mode set
INFO: Setting the install mode to be Typical
INFO: No. of NON_SSL_COMPLIANT suites is 0
INFO: Use admin file /tmp/cscotmp/CSCO.admin.
Daemon Management is not running.
INFO: Waiting up to 10 minute(s) for all our daemons to stop...
INFO: Checking for syslog server...
INFO: Using syslog facility, local1.
INFO: /tmp/finstall/packages/CSCOpix/pkginfo
INFO: /tmp/finstall/info
INFO: No ADVANCED_CHOICE section in TOC-file.
INFO: CSCOpix
Loading properties from info files, working...
Making a list of dependencies, working...
INFO: total size (MB) required = 1
INFO: For installing the product in '/opt/CSCOpx' -
INFO: Available Disk Space=16264 Mb.
INFO: Min Disk Space Required=1 Mb.
INFO: Sufficient disk space.
INFO: Management Center for Firewalls has been detected on your system, are you sure you want to reinstall? (y/n) - n
INFO: you have selected not to proceed with the reinstall.
INFO: Start the daemon manager manually.
INFO: Issue command :: /etc/init.d/dmgtd start.
Finished: Wed Dec 1 14:53:44 CST 2004
===============- Software Installation Tool Completed -==============
===================- Possible Warnings/Errors Encountered -===================
No Errors were encountered during installation.
drolemc
Level 6
Level 6
Please check whether Tomcat and Apache and also sqlCoreDB services are running on your machine.
