03-14-2023 07:43 PM
Hi All, i have set up a vpn site to site lab. There are 3 sites on my lab. I configurated vpn for DC site and another sites. And how can i set up vpn for the other sites. In order to every site can access to each other. I used IPsec for this vpn site to site lab.
03-15-2023 02:29 AM
With the limited information provided, very possibly like how your VPN lab was done.
What you're asking is much like:
Hi All, i have set up a L2 Ethernet site to site lab. There are 3 sites on my lab. I configurated L2 Ethernet for DC site and another sites. And how can i set up L2 Ethernet for the other sites. In order to every site can access to each other. I used fiber for this L2 Ethernet site to site lab.
03-17-2023 10:25 PM
This is my lab. My problem is the HO-HCM site cannot access to Branch-HCM.
03-15-2023 03:02 AM
you need some kind of hairpin, in HQ and it long story and not so accurate
instead use DMVPN which can make you connect Spoke-to-Spoke
03-15-2023 07:27 AM
". . . use DMVPN which can make you connect Spoke-to-Spoke"
That's what I too thought would be the likely approach, but I didn't suggest it as for all we know that's the particular VPN approach already being used in lab (although, if so, don't know what Phase DMVPN being used or supported).
03-17-2023 10:28 PM
Thanks for your suggestion.
03-17-2023 10:28 PM
Thanks for your suggestion. I'll try it.
