VSS management
chris57
In the VSS environment, where 2 switches work as one virtual platform, I was wondering if there is a way to be on the active switch, but view the hardware of the standby.
For example, if I wanted to see how switch 2 is performing as a piece of hardware, and not as a virtual domain, how would I do that.
How would I check for example, version, uptime, memory, buffers, power supply etc etc, without physically having to go in manually on the console port of switch 2.
Any advice would be appreciated.
Chris
Leo Laohoo
If I remembered correctly, there should be a command called "remote login" or "remote command".
