VTY Lines
M_Abdelwahed
Frequent Visitor
Frequent Visitor
I have a question that confuse me , when i issue the command "Show Users" on my 3845 router , i get in the output "VTY 0/0/0 " when i try to clear this line it doesn't recognize it , any idea about such line VTY number ?
balaji.bandi
To understand better why it was not worked.
can you post below output
#show users or #who
#show tcp brief
it will show you line numbers (before vty)
then you can clear with below :
#clear line 2 ( 2 is the line number example here)
BB
balaji.bandi
#show users or #who
#show tcp brief
BB
the command " #clear line 2 ( 2 is the line number example here) " has solved the issue , many thanks
