VXLAN - Vlans above 255 on into the thousands, best subnets to use
CiscoPurpleBelt
Level 6
Level 6
Just trying to find best practices.
So for VXLAN, if I have let's say vlan 600, what is best subnet IP to use for the SVIs or routing?
Obviosly can't do 172.16.600. I want things to flow so I was thinking 172.16.6.X for 600,
but what is good idea if it was for let's say VLAN 1000 or 6000? I can no longer match 3 octet with VLAN.
Any advice guys?
Ben Walters
Level 3
Level 3
The problem with setting things up logically like this is the inherent waste of addressing and VLANs. You can be super efficient with your subnets and have VLSM networks for everything but it won't be pleasing to look at.
However if you don't always need a /24 for the subnet you can break them down into /27 (8 subnets) or /28 (16 subnets) and fill in the VLAN gaps if you wanted to.
I will give you both examples based on VLAN 256
The base subnet would be 10.0.25.x if you wanted to use /27 subnets to fill in the gaps it would look like this, but you couldn't get right to 259 this way.
10.0.25.0/27 - 250
10.0.25.32/27 - 251
10.0.25.64/27 - 252
10.0.25.92/27 - 253
10.0.25.128/27 - 254
10.0.25.160/27 - 255
10.0.25.192/27 - 256
10.0.25.224/27 - 257
Optionally if you wanted to use /28 subnets to fill in the gaps it would look like this but you wouldn't utilize the entire /24 address space.
10.0.25.0/28 - 250
10.0.25.16/28 - 251
10.0.25.32/28 - 252
10.0.25.48/28 - 253
10.0.25.64/28 - 254
10.0.25.80/28 - 255
10.0.25.96/28 - 256
10.0.25.112/28 - 257
10.0.25.128/28 - 258
10.0.25.144/28 - 259
Ben Walters
Level 3
Level 3
I don't know of any best practices guides on subnet and VXLAN assignment but if you are looking to set a standard within your team or company you can come up with something that makes sense logically.
Personally if you are talking VLANs in the thousands I would move to the 10.x.x.x private range and only use VLANs in increments of 10
Starting with VLAN 10
10 - 10.0.1.x
20 - 10.0.2.x
990 - 10.0.99.x
1000 -  10.1.0.x
This would give you 99 VLANs in the range of 10-990, then increment the 2nd octet and start again in the 1000 range.
Each time you increment the 2nd octet it would give you another 100 VLANs to use and if you go up to 10.255.100.0 that would be 25,600 VLANs that you could use all logically segmented, which seems like more than you would ever need.
Here are some examples
10.15.25.x - VLAN 15250
10.0.15.x - VLAN 150
10.255.97.x - VLAN 255970
You could even break those /24 subnets into smaller ones and fill in the other subnets in the range from 0-9 adding even more VLAN possibilities.
If you are dead set on using the 172.16 range then you could use a similar method but it wouldn't be as obvious just by looking at the subnet or VLAN id
Hopefully this has been helpful or at least gave you some information to consider to come up with a system that works for you.
Awesome this is great!
If 10.0.15.X could be for VLAN 150, what about let's say VLAN 256?
If VLAN 10 = 10.0.1.x what could I use for VLAN 11?
I am trying to think of a way so I don't waste at least too much ip space and having difficulty?
Ben Walters
Level 3
Level 3
10.0.25.0/27 - 250
10.0.25.32/27 - 251
10.0.25.64/27 - 252
10.0.25.92/27 - 253
10.0.25.0/28 - 250
10.0.25.16/28 - 251
10.0.25.32/28 - 252
10.0.25.48/28 - 253
10.0.25.64/28 - 254
10.0.25.80/28 - 255
10.0.25.96/28 - 256
