web access on ncs prime
suthomas1
Level 6
Level 6
We have an NCS prime. We'r unable to login via GUI interface, password is unknown as the person handling the systems has left.
Using command prompt, we did password reset , following cisco guide, however the GUI is still inaccessible.
Any idea on how to proceed further to recover the GUI password.
Thanks in advance.
AFROJ AHMAD
Try this :
Login as admin mod and appaly the following steps,
NCS/admin# NCS password root password Public123
CompilerOracle: exclude org/snmp4j/Snmp.send
Loading USER - root
Validating new password..
Resetting password ..
Resetting password COMPLETED.
EXECUTION STATUS : Success
NCS/admin#
for more information ,check the below link:
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/tasks.html#wp1184161
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
It shows as new password is accepted, but ncs fails to login using it.
Have you tried multiple browsers other than chrome?  Or older versions of chrome
Firefox is "unsupported" but works fine.
Cheers,
Michel
Yes, tried IE as well.
