Web Base Authentication URL Problem
JohnJudi
Level 2
Level 2
Hi friends
My question may seem a little simple!
I've configured my asr 1002-x router for web-based authentication (Authentication Proxy).
but whenever I type router's IP address in browser, the webui page appears and I don't see the authentication proxy page.
what URL should I use to access authentication proxy page?
12 Replies 12
Georg Pauwen
just to make sure: are you using HTTP or HTTPS (as I believe HTTPS is not supported) ?
Can you post the running config of the ASR 1002 ?
Hello Georg
Thanks for the reply
I'm using HTTP.
and when I enable 'debug ip admission all' , it doesn't show anything.
the config looks good. Are you trying this from a Windows machine ? With Chrome/Edge/Firefox ?
yes I use Chrome, Opera and Firefox
but Each time I enter the address, the Webui page opens.
I don't see web-auth page.
How do I dsiable webui page to access web-auth page?
disable the http server:
no ip http server,
then re-enable it and type the IP address (192.168.201.1) into your browser again...
Thanks for replying me
Excuse me for my late
I tried
but I still see the webui page
can you test with local authentication ?
--> ip http authentication local
--> aaa authorization auth-proxy default local
I tried
But nothing changed
I do not think the problem is with the aaa, but I may be wrong
I think if I disable the webui interface, I can access the web-auth page.
With this command:
ip http active-session-modules
I do not know if I am right or not
balaji.bandi
Yuo mentioned ASR 1002-X , but the screenshot looks for me CSR1000v even config ?
which one is correct ?
BB
hello,
Yes you are right.
This is my Lab and I copied the ASR configuration to the CSR1000v to find the problem.
Can you post the config from ASR show run to look again what is wrong.
BB
I'm sorry but I don't have access to ASR show run right now
