Web configuration access impossible (switch 3560)
Ipefixe
When I want to configure my 3560 switch with the web interface, I reset it then press the mode button until the leds are green. Then I connect my pc to the switch with an ethernet cable, then I enter 10.0.0.1 in the search bar.
I access the interface of the choices (Telnet, Web, interfaces ...), but when I click on Web to access the page of configuration, google indicates to me impossible connection, page unavailable.
Thanks for your help !
balaji.bandi
Do you have basic configuration done in Switch ? like VLAN1 with IP ?
For using the Web GUI , you have must have permission of privilege level 15 access
create a user
username admin privilege 15 privilege 15 secret admincisco
then runn the http services
ip http server
ip http secure-server
ip http authentication login local
management ip
http://ip of the switch /
it will ask you username and pass
make sure you correct java version
BB
BB
Ok thanks, but when i configure the ip address of the web page ?...
Can you list the commands to access the configuration page ? From a switch factory configuration.
an you list the commands to enter to access the configuration page? From a switch factory configuration
Leo Laohoo
Maybe the appliance was upgraded by copying the BIN files only (and the HTML files may not be installed).
