03-13-2024 01:24 AM
Hi Community,
A daft question here. Can the 93108TC-FX support GUI access? I have done some checking into this which the documentation doesn't mention this ability. When checking the features on the switch, I do not see anything for http. As traditionally, you needed to set up some basic http commands for this to work. As this is missing from the platform, does anyone have any links to a definitive answer?
Thank in advance
Solved! Go to Solution.
03-13-2024 01:30 AM
- These devices (running nx-os) don't support GUI access ,
M.
03-13-2024 01:30 AM
M.
03-13-2024 01:40 AM
You can use Prime as a management platform. NX-OS does not have any embedded Web service. But you can also use Fabric Dashboard. Take a look at this link:
03-13-2024 02:35 AM
@Mark Elsen Thank you, this is exactly what I thought. Thank you for confirming.
