Weird WLC GUI Displaying
Wouter Dijkstra
Frequent Visitor
Frequent Visitor
Hi All!
I Have 2 controller (5520) with versie 8.5.151.0 and 8.10.141.0 and both are giving these weird caracters when prompting the login screens.
Also when i'm clicking around in the menus at random sometimes it won't load the page correctly or half like the picture example...
Who has the sollution! 🙂
Sandeep Choudhary
try to use internet explorer or firefox web browser!!
Dont forget to arte helpful posts
Sandeep Choudhary
Thanks for you're reaction! is there some particuliar reason why it doens't work any more with Chrome or Edge ? (i know its the same engine)
From our experience this is almost always caused by https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf74866
But that should be fixed by 8.10.141.0 (works for us anyway) but we do mostly use Firefox anyway - I haven't tried Chrome recently.
Can you confirm that you have https redirect enabled and you are using https for your GUI access?
If so then using a different browser will only be a temporary workaround on 8.5.151.0.  As WLC load increases the problem will return no matter what browser you use.  The only workaround then is to use http for GUI instead of https (and keeping in mind large number of clients will be affected by this too).  Upgrade to 8.10 is the only way to fix the root cause.
More details at https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html#anc6
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
