I am trying to find out where the NCS stores the configuration files it pulls for devices in the disk? I know I can log into the LMS server and access the shell and from there access the actual configuration files as .cfg files, i'm trying to find that for NCS, does anyone know?
they're on the local disk under the ftp directory---
logged in as the admin user run dir disk:/ftp command to see the config files----
if you have the root patch installed and are at the OS level; cd /localdisk/ftp.... the files are store there---
