Which are the real system and software requirements for Cisco CP?
djacksonv
Hi guys,
I am trying to use, since 1 week ago, the Cisco Configuration Professional but once this is installed it doesn´t startup when i click on the icon.
I have tryed with the 2.6 and the 2.8 versions, and none of them have worked.
I am aware of the Java and Flash settings for each one according to the Release notes. Here is my laptop setup and the versions of each plugin used.
1.- Laptop Settings:
Acer Aspire 4736
4 Gb RAM
I have a 320Gb HD with 2 partitions, the size of the partitions used for CCP is 80Gb.
Intel Core 2 Duo 2,2Ghz
Windows 7 Professional (x64) / Sevice Pack 1
14" LED LCD (1366x768)
Internet Explorer 11.0.9600
2.- Using the CCP 2.6
Java Plugin 1.6_11
Runtime Parameter set to: -Xmx256m -Dsun.java2d.d3d=false
Java Advance Tree: (Uncheck) Activate Next Generation Java Plugin
3.- Using the CCP 2.8
Java Plugin Version 7 update 60 (compilation 1.70_60)
In both cases didn´t work i t always says: "Internal error has ocurred. Close CCP and restart the aplication".
Please help me i am upset with this and i really need this to prepare my CCNA Sec track.
Marvin Rhoads
For CCP 2.8, did you download and install the full version for PC (filename "cisco-config-pro-k9-pkg-2_8-en.zip")?
I've used that software fine on several Windows PCs.
Yes Sr. this is the zip file i am using.
I have installed the CCP in a winXP 32bits and it work fine. But in my laptop it doesn´t work yet.
Also i tried today with the JRE 1.6.0_31 and nothing the same message.
BTW, when i try to run the CCP, for first time, each time i have installed the internet explorer window says that i don´t ave installed the flash player. But i have it Activex and Plugin Version is 14.0.0.145, for both.
Thos is the same configuration for the WinXP PC.
