WLC and External DHCP
Hi guys,
today I was tryng to do a lab with a WLC-3504 and VLAN using an external DHCP.
The Issues is that only the pool made inside the WLC are working, when I swap the primary dhcp server with the external one it stop to works and the Clients are not anymore available to find an address.
Can someone help me?
7 Replies 7
ammahend
controller>adanced>DHCP enable proxy
Under interface set DHCP proxy mode to global with IP address of DHCP server as primary DHCP server.
Additionally remove the DHCP override if you configured under WLAN>Advance to use internal DHCP on WLC, since now you are using external DHCP.
-hope this helps-
I have only this option.
that's good enough,  remove internal DHCP override WLAN advanced config, if you still are not getting addresses, send output of
show wlan <wlan-id>
debug dhcp messages
debug dhcp packets
-hope this helps-
Can I send to you the file of packet tracer?
I don't know how to see this options.
sure I didn’t know this was packet tracer. I can look at it later today.
-hope this helps-
Thanks!
I sended to you a private message.
guruvignesh
Hello ludo,
  • Safe: not harmful, unethical, racist, sexist, toxic, dangerous, or illegal.
  • Sensitive: not insensitive, sexist, racist, or socially inappropriate.
  • Appropriate: not controversial or objectionable based on common sense ethical and moral standards.
  • Non-violent: not promoting violence, hatred or discrimination.
  • Non-sexual: not sexually suggestive in nature.
  • Private: not seeking private information about individuals.
  • Creative: if the response sought does not violate safety guidelines, I will respond creatively.
