12-12-2013 11:59 PM
Hello everyone,
we are facing the following issue: the SNMP poll is showing wrong values for ciscoEnvMonSupplyStatus when at the same time the "show env all" shows that there is nothing wrong with the power supplies.
Here is the example:
ciscoEnvMonSupplyStatusDescr.1057 Sw1, PS1 Faulty, RPS NotExist OctetString 192.168.49.28:161
ciscoEnvMonSupplyStatusDescr.1058 Sw1, PS2 Faulty, RPS NotExist OctetString 192.168.49.28:161
ciscoEnvMonSupplyState.1057 notFunctioning (6) Integer 192.168.49.28:161
ciscoEnvMonSupplyState.1058 notFunctioning (6) Integer 192.168.49.28:161
------------------ show env all ------------------
FAN 1 is OK
FAN 2 is OK
FAN PS-1 is OK
FAN PS-2 is OK
SYSTEM TEMPERATURE is OK
System Temperature Value: 31 Degree Celsius
System Temperature State: GREEN
Yellow Threshold : 46 Degree Celsius
Red Threshold : 60 Degree Celsius
SW PID Serial# Status Sys Pwr PoE Pwr Watts
1A C3KX-PWR-350WAC AZS161803GQ OK Good Good 350/0
1B C3KX-PWR-350WAC AZS161803GT OK Good Good 350/0
I have seen that this is a more or less a known issue and there are plenty of bugs for it, but exactly for our hardware and IOS (C3560E Software (C3560E-IPBASEK9-M), Version 15.0(2)SE2, RELEASE SOFTWARE (fc1)) I cannot find any exact information.
Please, advice if we are hitting some known bug which I cannot locate.
Vesselin
SW Status RPS Name RPS Serial# RPS Port#
1 Not Present <>
12-16-2013 11:16 PM
Hi ,
I have issue while generating alerts for the CISO nexus device.
snmp laert tool: Solarwinds error : The OID is not supported,
Can anyone tell me the OID for the CISCO nexus 2k, 5K devices.
I am trying to generate the Temp alert.
THANKS
