ws-c3650 switch output drops inquiry
KDG_work
Hi all.
I am using two WS-C3650-48PD-S switches, and Gi1/0/47 and Gi1/0/48 ports for each switch are connected by setting them as port channels. ( Boot System : cat3650_caa-universalk9.16.06.04a.SPA.bin )
When checking with the show interface command, the number of output drops is increasing.
Is there a cause and solution?
qos queue-softmax-multiplier 400
Run above command and check drop
MHM
MHM
Thank you for your reply.
I have additional inquiries.
Are there any documents, such as notices, from Cisco regarding the symptoms?
