02-24-2022 07:35 AM - edited 02-24-2022 07:37 AM
hi all,
trying zabbix out and i want to make a template for my cisco switch so it picks up all the OIDs automatically and any other switches for that matter
ive enabled SNMPv2 on the switch, added it to zabbix via ip, its picked it up
but i want it to auto dicover all the OIDs and the names
is there anway to do this
https://www.youtube.com/watch?v=CkQSUCw40KI
thanks,
rob
02-24-2022 08:18 AM
This is more of NMS software you using to discover the IP and Names. as per the Device concern you enable SNMP and commnuity thats all.
02-24-2022 08:21 AM
what do you guys use for monitoring switches, what product i mean?
02-24-2022 09:02 AM
Depends on requirement abd business budget
I have tried all opensource as below :
MRTG
CACTI
Zabixx
LibreNMS
nagios
PRTG (Free and paid)
SOLARWINDS
LogicMonitor
manageengine
02-24-2022 09:08 AM
and out of all of them what do you say is the best or the better one that can get all the OIDs automatically once it detects the device you added has got SNMP enabled?
