active FTP does not work
lkadlik
Level 4
Level 4
I have an asa 5520 that works fine if you are using passive ftp and ftp inspection is on globally. It is not working for an active ftp session. I tried allowing all ports back to the external ip address of the internal client as a test and this did not work either.
Cisco Adaptive Security Appliance Software Version 8.0(3)
Device Manager Version 6.2(3)
policy-map Global_Policy
description Global Policy for Traffic Inspection
class Inspection_Default
  inspect dns
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect icmp
  inspect ipsec-pass-thru
  inspect mgcp
  inspect pptp
  inspect rsh
  inspect rtsp
  inspect sip
  inspect skinny
  inspect snmp
  inspect sqlnet
  inspect tftp
  inspect xdmcp
  inspect http
I read another article saying that this command needs to be on the asa "fixup protocol ftp 21"
If this is enabled will it show on the firewall?  How do I enable it?  Will it cause any issues if I enable it ?  Is there anything else the issue could be?
Thank you.
Lynne
lcaruso
Level 10
Level 10
Without looking over many pages of release notes with issues addressed, I cannot say definitely that this would address your problem, but I still recommend you upgrade from 8.0(3) to 8.4(2).
There have been so many issues addressed since that version of code, and in general it is not a good idea to remain on an x.0 release of code indefintely. I have personally seen upgrades from 8.0x solve several problems.
Also, ASDM 6.4(5) would be a good idea.
