ASA 5505 with BTnet SIP - Policing and Priority Queing settings
Ian Walker
From my own research I've put together this config for an ASA 5505 (9.0) to prioritse SIP and police IP traffic for the BT SIP  service over BTnet
All comments welcome. As I understand it, you prioritise outgoing SIP/RTP traffic on the "outside" interface and police ip traffic on the "inside" interface?
BTnet SIP service with the following topology
Part 1 of 2 :
Set up Priority Queing for outgoing SIP and RTP traffic
! Enable a priority queue on the outside interface
priority-queue outside
! Create rtp object-group
object-group service rtp udp
port-object range 49152 65535
! ACL for SIP and RTP From dmz
access-list VoIP-Traffic-OUT extended permit tcp 192.168.0.0 255.255.255.0 host 85.119.63.4 eq sip
access-list VoIP-Traffic-OUT extended permit udp 192.168.0.0 255.255.255.0 host 85.119.63.4 object-group rtp
! Class Map - Match the ACL
class-map Voice-OUT
match access-list VoIP-Traffic-OUT
exit
!create a class map to identify the traffic for which you want to perform priority queuing.
policy-map PRIORITY-POLICY
class Voice-OUT
priority
! Identify all traffic for traffic shaping; you can only use the class-default class map, which is defined as match any, because the security appliance requires all traffic to be matched for traffic shaping.
policy-map QOS-TRAFFIC-OUT
 class class-default
  shape average 10000000
!(10Mbps Upload)
service-policy PRIORITY-POLICY
! Apply the shaping policy to the outside interface
service-policy QOS-TRAFFIC-OUT interface outside
! Show Commands :
ASA#show service-policy priority
ASA#show service-policy shape
ASA#show service-policy policy
Part 2 of 2 :
Configure traffic policing for incoming and outgoing ip traffic to the Data LAN (Inside interface)
! Traffic Policing – incoming and outgoing – per interface
access-list DataLAN extended permit ip 172.23.127.0 255.255.255.0 any
access-list DataLAN extended permit ip any 172.23.127.0 255.255.255.0
class-map DataLAN
Description Data LAN Traffic
match access-list DataLAN
policy-map Police-LAN
class LAN
police output 20000000
police input 10000000
Service-policy Police-LAN interface inside
*in this case,
Output = “Download”
Input = “Upload”
2 Accepted Solutions
Vibhor Amrodia
I think the configuration seems to be good.
The only thing which is incorrect is this:-
Output = "Upload"
Input = “Download”
Thanks and Regards,
Vibhor Amrodia
Hi Ian,
On the Inside interface it would be the same that you pointed out. :)
My concern is that why are we trying to limit the Intra interface traffic as well for the policing ? As you have the destination as "any" in the Class map ACL.
I think you might think of denying the traffic from this ACL to the internal Interfaces (for Ex:- DMZ) and police the rest of the traffic.
You are already policing the traffic closest to the source which is recommended.
Thanks and Regards,
Vibhor Amrodia
Vibhor Amrodia
Output = "Upload"
Input = “Download”
Thanks and Regards,
Vibhor Amrodia
Hi Vibhor
Are you sure that's right?
On the "Inside" interface, surely 'Download' will be the output,?
http://youtu.be/Xb2A3Xekp7Q?t=2m48s
Kind regards
Ian.
Hi Ian,
Thanks and Regards,
Vibhor Amrodia
