ASA 5506 - NAT Problem - Need to Prove it's not the Firewall
Dean Romanelli
Level 4
Level 4
Hi All,
I have a site that has an internal VOIP subnet (192.168.9.0/24) hanging off of a Cisco ASA 5506. On that subnet, there is a local IP-PBX: 192.168.9.11.  That PBX needs to be visible publically to a SIP server in the cloud on the internet.  The WAN subnet is a /30, so I need to interface NAT that 192.168.9.11 PBX so it is seen publically when it is called from the outside on a range of ports, which are UDP 46750 - UDP 50750.  I have set this up to the best of my knowledge, but it is not working.  The initial SIP exchange completes bidirectionally, but I begin to get nothing back from SIP Server once the UDP traffic starts to flow from the PBX.  I need to prove that this is not the ASA and the SIP Server has a problem.  Below is my NAT config, and attached is my full ASA scrub.  Can anyone validate these configs as correct or spot an issue if incorrect?
Relevant NAT Configs:
object network Avaya_IP_PBX-PRI
host 192.168.9.11
object network Avaya_IP_PBX-BKP
host 192.168.9.11
object service VOIP-UDP-46750-50750-PRI
service udp destination range 46750 50750
object service VOIP-UDP-46750-50750-BKP
nat (outside,VOIP) source static any any destination static interface Avaya_IP_PBX-PRI service VOIP-UDP-46750-50750-PRI VOIP-UDP-46750-50750-PRI
nat (backup,VOIP) source static any any destination static interface Avaya_IP_PBX-BKP service VOIP-UDP-46750-50750-BKP VOIP-UDP-46750-50750-BKP
Relevant Access Configs:
host 192.168.9.11
host 192.168.9.11
object-group service VOIP-TCP-Ports-PRI tcp
port-object eq sip
port-object eq 5061
object-group service VOIP-UDP-Ports-PRI udp
port-object eq sip
port-object eq 5061
port-object eq 50795
port-object range 46750 50750
object-group service VOIP-TCP-Ports-BKP tcp
port-object eq sip
port-object eq 5061
object-group service VOIP-UDP-Ports-BKP udp
port-object eq sip
port-object eq 5061
access-list outside_access_in extended permit tcp any object Avaya_IP_PBX-PRI object-group VOIP-TCP-Ports-PRI
access-list outside_access_in extended permit udp any object Avaya_IP_PBX-PRI object-group VOIP-UDP-Ports-PRI
access-list backup_access_in extended permit tcp any object Avaya_IP_PBX-BKP object-group VOIP-TCP-Ports-BKP
access-list backup_access_in extended permit udp any object Avaya_IP_PBX-BKP object-group VOIP-UDP-Ports-BKP
Ok it looks good. this is showing all the path the packet will take and, on the firewall, we can see it's sending it to your internal PBX.
You can also confirm by running a tcpdump on ASA on on the switch where PBX is connected to. If you see trafic, the issue is your SIP provider or application layer.
If you have the real public ip of your sip provider, you can re-run the packet-tracer command by replacing 8.8.8.8 with your SIP provider.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
5 Replies 5
Francesco Molino
To test, can you do a packet-tracer please:
packet-tracer input outside udp 8.8.8.8 46750 x.x.x.x 46750 where x.x.x.x is your public ip
Francesco
Certainly. Please see below:
FW7BuenosAires-SC5506# packet-tracer input outside udp 8.8.8.8 46750 170.xx.xx.197 46750
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
NAT divert to egress interface VOIP
Untranslate 170.xx.xx.197/46750 to 192.168.9.11/46750
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group outside_access_in in interface outside
port-object eq sip
port-object eq 5061
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 8.8.8.8/46750 to 8.8.8.8/46750
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 9
Type: NAT
Result: ALLOW
Config:
Phase: 10
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 1592613, packet dispatched to next module
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: VOIP
output-status: up
output-line-status: up
Action: allow
Francesco
Thank you Francesco.  Yes, I do have the IP of the SIP provider.  I've rerun the packet tracer using that IP and the results are identical to the above results that used 8.8.8.8.
I have run capture tcpdump and what I see is the PBX and SIP server exchange initial 5060 and 5061 TCP traffic but then once RTP UDP traffic starts flowing, it is one way only - meaning that my PBX is sending RTP UDP traffic to SIP server but I am not getting anything back from it.
Thank you for the validation. If you are in agreement, I will publish that this issue is not the ASA.
Ok, in your global policy, can you check if you have inspect sip?
Francesco
